Member # 12382
auto tranny s/k 89
hello all
i have an 89 s/k 4x4 auto tranny that i would like to mate up to my 1.6 but with the t-case its just toooo long is there a chance that i could get away with putting a 2wd tail houseing on this tranny or would i have too change the output shaft on the tranny the tag on the tranny reads {d27 3381781} thanxs rabidray |
I actually looked into it. IT costs about $500CAN to put new tail housing parts on to convert it to 2wd. There is a planetary gear set in the tail shaft of the 2wd's. If you can find a 2wd tranny at a wreckers they should swap you straight ove. But finding one is like finding Hens Teeth. Good Luck, Hope this Helps.
[color=yellow]Zuki Service Truck[/color] Driver May Take SCARY lines! [color=pink]Just a man with a Sawzall[/color] |
Member # 12382
hi
hey these planetary gears are they for reduction oor induction or do they reverse rotation ive seen a thread on this site for divorceing a toy t-case whos to say i couldnt do the same thing with this tranny if the p gears are steping up the gear ratio who needs em if there step down.;..... but at any rate the reduction could be handled by the sammy t-case as you said the 2wd tranny are hard to find 4wd is more common it would make sense to pursue this a little further just to see were it goes the reason why i posted this is because i didnt know i think a lot of people would be interrested in this kind of mod does any one know how mike schaffer did the dual t-case thing kuz that was my original intent rabidray |
I belive it was with an OTT adapter. I was going to run that setup but I am going to swap to a diesel so my 3speed tranny is out of the question.
As for the gears I am unsure. All I know is the tranny is 1:1 in drive and so is the t case in 2wheel drive and 4 wheel drive. Hope this helps a little bit.
