1.6 won't fit!?!?! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-23-2007, 09:19 AM   #1 (permalink)
Member # 103366
Question 1.6 won't fit!?!?!
Hey all, im new to this forum and i am in need of some help. I just got my 1.6L 8v lowered into my 87 samurai and things just arent lining up. I am using the rocky road swap kit and have read and reread the directions. the engine is bolted up to the tranny but for some reason the MOTOR MOUNTS WONT MATCH UP!! i have no idea what to do.. also, there is not a chance in hell the hood is going to close. any suggestions??
thanks a lot for your help
87 sammi is offline   Reply With Quote
Old 11-23-2007, 10:11 AM   #2 (permalink)
Member # 76617
Not sure on the mounts but you have to raise the front body mounts an inch (spacer) or so I,am told
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
A Samauri is not an f-toy
A samauri is not an f-toy
benttoy is offline   Reply With Quote
Old 11-23-2007, 05:22 PM   #3 (permalink)
Member # 94747
Welcome to the forum new guy. I have a 1.6 16v in the wifes sammy and it fits with no body lift. It also has plenty of clearance under the hood. Could you have the motor mounts switched sides? They are different from right to left on my petroworks kit.
jr4x is offline   Reply With Quote
Old 11-23-2007, 05:49 PM   #4 (permalink)
moveaside's Avatar
Member # 11983
Loosen the mounts and spin them around like an eccentric to aid yourself in the line up process.
My crappy build
[url]http://www.pirate4x4.com/forum/showthread.php?t=587635[/url]
moveaside is offline   Reply With Quote
Old 11-23-2007, 10:09 PM   #5 (permalink)
Member # 103366
well i have a 6" lift so i wouldnt think that clearance would be a problem. as for the motor mounts being flipped with the diff sides, i have checked and rechecked my directions and i have the proper offset castings in the right spots. im completely stumped.
Old 11-23-2007, 10:30 PM   #6 (permalink)
Scott410's Avatar
Member # 89908
Your 6" lift has nothing to do with the clearance for your hood, unless you have a 6" body lift that is, which I hope you don't. If you can't figure out how that motor goes in, post some pic's or you can send it to me and I will get it to fit in my rig.
http://www.zukikrawlers.com/showthread.php?t=14532
Scott410 is online now   Reply With Quote
Old 11-24-2007, 11:37 AM   #7 (permalink)
Member # 102051
Hey, fellow newbie here with the same project. I have an '86 with a 1.6, stock 1.3 tranny with the same adaptor plate and motor mounts. I've had big block Chevies give me less trouble but it can be done.
Get the engine bolted up to the bell housing and you have enough wiggle room (1/4"?) to slide the mounts in and out between the motor and crossmember. Identify the mounts with a 1 & 2 , A & B, whatever works for you. It CAN be done, identifying them makes it less frustrating because you only do it five times and not fifteen.
Loosen the bolts holding the mounts to the block also, this helps wiggle in other directions.
Are you using the 1.3 or the 1.6 mounts?
Dan
914Driver is offline   Reply With Quote
Old 11-24-2007, 11:59 AM   #8 (permalink)
Member # 74526
get the petro works kit. mine bolted up, no problem.
notjeep is offline   Reply With Quote
Old 11-24-2007, 03:23 PM   #9 (permalink)
Member # 103366
okay so the update is that i now have the motor mounted up and everything, but the hood still doesnt come close to shutting. i guess ill have to get creative and make a cowl induction style looking hood. what ya'll think?
Old 11-24-2007, 04:26 PM   #10 (permalink)
Member # 8783
mines got a big hole cut in the hood, and a piece bent up around it to raise it about the 1" it needed
1 ton bronco
custom zuk or two
BurnedBronco is offline   Reply With Quote
Old 11-24-2007, 07:26 PM   #11 (permalink)
Member # 15908
Send a message via AIM to Nowhere Send a message via Yahoo to Nowhere
Easies thing to do is to change the motor mounts to the dodge style.
The Dodge 319 motor mounts are super beef compared to the stock samurai ones and they are CHEAP (less than 10 each).
You'll need to drill the mouting holes out to 1/2" and shimmy the engine in there. A pry bar is needed to jiggle the mounts into position.
The dodge mounts lower the engine by about 1/2 or 3/4 of an inch. I've got a 16v with NO body mount mods, lots of hood room
Your flesh is a relic, a mere vessel. Hand over your flesh and a new world awaits you. We demand it.
Nowhere is offline   Reply With Quote
Old 11-24-2007, 08:33 PM   #12 (permalink)
Member # 50557
What the hell?? I've done a lot of 1.3 to 1.6 swaps and have never ran into hood problems. But, that's probably because it is Trail tough stuff...
Sounds like bay, not ass.
Bass Man is offline   Reply With Quote
Old 11-24-2007, 09:39 PM   #13 (permalink)
Member # 94747
Yeah? second the what the hell!!!!!!! My petroworks kit makes the engine clear the hood with at least an inch to spare. With no body lift or mod OF ANY TYPE. More reason for me to stay away from RR!
Old 11-24-2007, 09:55 PM   #14 (permalink)
Member # 103366
well screw RR cause they have givin me probs from the start. im just gunna have to get creative and make it look cool too. thanks for all the input guys!! ill keep ya posted on what is happening. tomorrow im gunna try and get the damn thing wired up. wish me luck!!
Old 11-25-2007, 06:40 AM   #15 (permalink)
Member # 8783
mine is because i have the petro injection 8 valve intake tube running ontop of the motor is why mine doesnt clear, and mine isnt RR..............
of coruse my hood also looks like the fat bitch tapped danced onit till she died with the amount of backflips, endos and trees it has eaten. the one roll that flattened the front part of the hood down acually pushed the radiator fill tube 1/2" down into the tank.....
1 ton bronco
custom zuk or two
Old 11-25-2007, 07:14 AM   #16 (permalink)
Member # 102051
Yeah, get creative; the kit says right in it that you need a 1" body lift. I'm opting for a cowl induction type hood scoop. Got MIG?
Dan
Old 11-25-2007, 07:45 AM   #17 (permalink)
Member # 103366
thanks alot guys for all the input. ill keep ya updated as to what is happening!! thanks again
Old 11-25-2007, 08:08 AM   #18 (permalink)
Member # 84613
I shamfullly admit that I have the RR 1.6 kit in my zook but I didn't have any issues installing mine! No body lift and theres at least an inch between the hood and carb!
hellbilly75 is offline   Reply With Quote
Old 11-25-2007, 10:46 AM   #19 (permalink)
Member # 8783
Originally Posted by hellbilly75 View Post
I ut I didn't have any issues installing mine! No body lift and theres at least an inch between the hood and carb!
key word being carb.............
1 ton bronco
custom zuk or two
Old 11-26-2007, 01:50 PM   #20 (permalink)
Member # 85796
I have 16v in 87 street sami, and 8v in buggy and no body lift, about 1 in to spare on both
BIGJOEDUCKSLAYER is offline   Reply With Quote
Old 11-26-2007, 04:32 PM   #21 (permalink)
Member # 103366
is your 1.6 efi or carb?
Old 11-26-2007, 04:52 PM   #22 (permalink)
Member # 16608
Cut the underside hood brace out...stand back...slam the hood.
It'll close...trust me...I know.
'88 Zuk
TatorZuk is offline   Reply With Quote
Old 11-26-2007, 05:27 PM   #23 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
I used a 1.6 8v from a '93 and the 2wd tranny with it. 318 mounts and plenty of space under the hood.
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 11-26-2007, 09:51 PM   #24 (permalink)
Member # 8687
I cut the brace out of my hood too. The part that goes from the throttle body to the air filter is taller on the earlier 1.6 8valve engines, so that adds to the problem if you have that style.
The word "jones" is a slang term meaning to crave, want, or desire; or, to feel withdrawal from an activity of passion. The general slang meaning is often associated with addictive substance habits but can be applied on a more universal scale.
jones is offline   Reply With Quote
Old 11-27-2007, 01:00 AM   #25 (permalink)
Member # 89104
Do yourself a favor.
Splurge the $3.00 to $5.00 per dodge 318 motor mount. A total of maybe $10.00 and your hood will shut just right without mods. I think the mounts came from a 70's dodge BTW
I would rather buy new mounts than try and dick with fabbing a new hood any day. Not only does it drop the engine down 1" or more, keeps the center of gravity lower.
It doesn't lower the engine a lot but I've been in spots where the drive train being 1" lower would have kept me from having a friend push on my samurai to keep it from tipping over while I drove out of a tough spot
skyman6529 is offline   Reply With Quote
