Member # 89600
want to turbo my 1.6 16v
possible?
let me know how if it is. what am i looking at as far as cost and time. my motor is in a buggy, lots of room to play with.
[URL="http://www.myspace.com/jasondonnel"]http://www.myspace.com/jasondonnel[/URL] |
Member # 34724
Its either reliable and expensive or cheap and not reliable.
Its gonna get costy if you do it properly. This is what you would need to get one going: Manifold w/ turbo flange Exhaust (2.5 inch) Turbo (buy a used one, like a Mitsu td04 rendition) w/ built on wastegate Piping and silicone couplers Blow off valve Fuel pump Engine management system (Motec, megasquirt, etc) Intercooler (possibly needed if you are running higher boost) 2 hrs worth of dyno tuning That would get ya going. Its expensive.
CrawlinBC.com I get nervous in social situations motherfucker! |
Member # 89600
thank you. so now the question is, is the extra horespower that it gives worth the money?
I was considering putting a turbo on my 16 valve but I don't think it's worth it. You can probably swap in a more powerful motor for cheaper. I am thinking that when I decide I want more power that I am going to swap in a 2.7l V6 out of a XL-7 because it will bolt up to my existing doubler. Also, stock motors are much more reliable.
Member # 11097
there is a turbo kit on ebay right now for a 1600 16v ... 8hrs left
http://cgi.ebay.com/ebaymotors/ws/eB...175007270&rd=1
Jim Stopinski http://www.projectsamurai.com | http://www.kifourwheelers.com |
#7 (permalink) | |
If you're in a buggy, you'll have lots of other options - Mercedes diesel, 22r... What application are you going to use this vehicle in? |
#8 (permalink) | |
Member # 89600
Member # 34724
The only problem with boosted applications is that they are extremely sensitive. If you cant adjust air/fuel mixtures on the fly, elevation sure changes the way it runs. You could even get into a situation where you are detonating, which is no good.
I would do it for pimp factor, its on a buggy so thats good, just take into condsideration when you are doing the stuff that you know where water tends to hit. I learnt in science a splash of cold water on a stupid piece of metal can cause problems
#10 (permalink) | |
Member # 89600
