Scout Power Steering on a Samurai - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-12-2007, 10:56 AM   #1 (permalink)
Member # 104535
Cool Scout Power Steering on a Samurai
I have been thinking about this setup on my sami for a while. Does anyone have any info or pics of this setup. I am currently running the sidekick/tracker setup w/sidekick drop pitman arm reamed to fit a 1-ton tie rod end and its not working out with 37" Iroks. Thanks 4 any input.
Sami88 is offline   Reply With Quote Quick reply to this message
Old 12-12-2007, 06:22 PM   #2 (permalink)
jr4x's Avatar
Member # 94747
Some one posted in the dana axle swap FAQ with pictures of scout axles and steering in a sammurai.
jr4x is offline   Reply With Quote Quick reply to this message
Old 12-13-2007, 05:05 AM   #3 (permalink)
Member # 27862
I'm running a scout forward throw and pump in my zuk,work's great.
86 samurai-tubebed,1link rear,22RE,l52 trans/w56,stock case 118"WB,35"mtr's
O'neal is offline   Reply With Quote Quick reply to this message
Old 12-13-2007, 10:39 AM   #4 (permalink)
rotozuk's Avatar
Member # 8965
I should have some pics around here somewhere....
Not sure this is the ideal box for the samurai as it is very large and the sector shaft is so long. You will want to source another pitman arm as the scout unit is very long and will give you to much throw for most axles. I used a Ford pitman. There are a couple of different ratios on these boxes. I think mine was a the "fast" one, and it steered like a dump truck. But the thing had great power.
You might look into something like a Chevy Astro steering box as it is also reversed, but without the huge sector shaft. That sector shaft was getting in the way of my suspension up travel!
-Wayne
rotozuk is offline   Reply With Quote Quick reply to this message
Old 12-13-2007, 11:55 AM   #5 (permalink)
Member # 104535
Thanks 4 the pictures, what years does the reversed box come on the Astro?
Old 12-13-2007, 01:17 PM   #6 (permalink)
Member # 9011
Rotozuk: Where did you source the joint for the steering shaft? and what did you have to do to make it work? any pics? What ford pitman did you use?
I already have my scout box mounted on the frame. I've been trying to decide what to do with the steering shaft though. I'm also going to try a wagoneer pitman arm and see if it clears (I'm running stock YJs shackle reverse up front and Scout II axles)..
87 Samurai/ 90 Chevy
weezman1 is offline   Reply With Quote Quick reply to this message
Old 12-13-2007, 05:02 PM   #7 (permalink)
Member # 27862
here's some of my setup.....
Old 12-14-2007, 10:00 AM   #8 (permalink)
Member # 26115
We ran the boxes on our trackers no problems.....
they were very strong and worked awesome for 36 IROKS......
My box is for sale now that we are going full hydro.......
2002 Suzuki XL-7 37's-1Tons
Project XL-XL7
zuki4x4chick is offline   Reply With Quote Quick reply to this message
Old 12-14-2007, 11:02 AM   #9 (permalink)
rotozuk's Avatar
Member # 8965
I bought the u-joint from a local sand/race shop, McKenzies. They are on the web and have a nice selection of stuff at very good prices. The joint is tig welded to a stock Samurai shaft, and bolts to the Saginaw input shaft.
If you are running the Scout II axles, then you should be able to use the stock Scout Pitman arm. I was running this on a Toy axle.
-Wayne
Old 12-14-2007, 11:03 AM   #10 (permalink)
rotozuk's Avatar
Member # 8965
As far as I know, all of them. Vans have some space limitations in the front and tend to have reversed boxes.
-Wayne
