Member # 11983
Suzuki interchangeable parts thread
I'd like to start a thread that lists all the interchangeable parts possible for a suzuki or sidekick. I'd love to have an accurate listing all compiled in one thread of all the possible swaps. After searching for some time now I've found a lot of misinformation. Lets get one go to thread for all the possibilities that can be done. Plus the thread can be policed much like the Zuk Faq. From 1.3l to 1.6l engine parts to toy steering shafts to sammy to kick/tracker to anything else. It doesn't need to be able to bolt right up but come together with at least little to no modification. Please help out and post up your knowledge.
My crappy build [url]http://www.pirate4x4.com/forum/showthread.php?t=587635[/url] |
Member # 8687
There is a thread like this somewhere in here from a couple years ago. I remember it had some good stuff in it too.
The word "jones" is a slang term meaning to crave, want, or desire; or, to feel withdrawal from an activity of passion. The general slang meaning is often associated with addictive substance habits but can be applied on a more universal scale. |
Member # 11983
Time for an update there's a lot of new members everyday that might have something to see or that they know. For example I found this one out after the fact. I was sitting there about to cut my sammy steering shaft in half and weld it together with my toy IFS steering shaft out of the junkyard when I took a good look at the bolt pattern. I took the sammy part that went to the steering wheel ditched the crappy sammy rag joint and put the lower half of the toy steering shaft on it. I then got rid of the rag joint and it bolts up to my IFS box. Two birds one stone.
Member # 8687
I know there's new members, but the old ones know more.
![]() I just meant that we should have the old info here as well. I tried searching for the old thread, but I can't find it right now. If someone else finds it they should link it to this post. I said it in the old post, but I know that a Chev Sprint has a few interchangeable parts like the timing cover and fuel pump. There's likely other parts too like the alternator and water pump.
Member # 11983
You need a l.3l distributor and intake manifold bolted up to the side of your 1.6l 8 valve in order to run the propane kit. So its not something you should throw away.
I've also found out that after Trail Tough modifies a 16 valve harness you can use a manual or auto computer to run either tranny because the connections going to the tranny are eliminated Then there is the 1978 Dodge truck with the v8 318 that you can use to upgrade the motor mounts in a sammy. They lower the engine 1/2" and you need to hog out the mount holes a little but they bolt right in.
My crappy build [url]http://www.pirate4x4.com/forum/showthread.php?t=587635[/url] Last edited by moveaside; 01-08-2008 at 06:19 PM. |
#8 (permalink) | |
Member # 11983
