99' 2.0 tracker swap into sammi? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-26-2008, 07:17 PM   #1 (permalink)
Member # 95698
got a slamming deal on a 2.0 from the local pick and pull. $53 for eveything all accesories, computer, engine wiring, stater, and cat.. so now i'm looking for some help. as far as the wiring its going to take a bit of work but i'll figure it out. what i'm looking for help with is the mateing of the sammi trans with the 2.0? does anyone have any info in reagrds to this, it would be greatly appreciated. what i was wondering is if i could just use the flywheel for a 2.0 with slight modification? thanks in advance
irishzuk is offline   Reply With Quote
Old 01-26-2008, 07:32 PM   #2 (permalink)
Member # 89600
goo deal I would pay 53$ in gas to get it for that much!!
[URL="http://www.myspace.com/jasondonnel"]http://www.myspace.com/jasondonnel[/URL]
fordori is offline   Reply With Quote
Old 01-26-2008, 07:52 PM   #3 (permalink)
Member # 106586
Two more things to make sure you have are the pressure sensor off of the fuel tank and the instrument cluster from the dash. You need the pressure sensor so you can mount it on your samurai tank, and the instrument cluster so you can remove the speed sensor from the Kick speedo and put it in your Sami speedo.
You need a modified flywheel to mate it to the samurai transmission. You also need an adapter plate, motor mount adapters, an electric fan w/shroud and 3 core radiator.
Trail Tough sells a complete kit with all of the stuff for a swap (including the wiring harness conversion and speedo conversion) for $1250. Aftermarket 4x4 is the only other place I know of that sells a kit for the DOHC conversion (1.8L and 2.0L) I think Sean DeVinney probably outsources conversion kits to Trail Tough since their prices are the same. If you wan't some personalized help though and someone that will get helpfull and informative answers to you, go through Sean over at Aftermarket 4x4. He was really helpfull in answering all my questions.
You can only smell fear if the fearfull have loose bowels.
Baratacus is offline   Reply With Quote
Old 01-27-2008, 09:18 AM   #4 (permalink)
Member # 95698
from what i have read i don't need the pressure sensor. with out it it will just have a check engine light. as far as the speed sensor i thought of it but i don't think it is really needed. what do you mean by the speed sensor from the kick speedo? this motor came out of a tracker. also why wouldn't i be able to run the stock rad instead of the 3 core rad trail tough is running? thanks for all the advise i'm just trying to cover all my bases but i jump in. keep it coming.
Old 01-27-2008, 09:30 AM   #5 (permalink)
Member # 106586
tracker..sidekick.. you know what I mean. I'll try to watch my P's and Q's...
If you don't mind the check engine light and you don't have to pass emission testing then you don't need the pressure sensor. If you don't mind the speedo not working right.. you don't need that part either.
If stock you mean the stock Samurai radiator, it isn't going to keep that engine cool enough with an electric fan on it. The 1.8 and 2.0 engines don't have engine driven fans on them.
If you mean the stock Tracker radiator, then you'll need to do some cutting to get it to fit. I don't know how much cutting since I personally don't know any one thats done it. I'm sure SOMEONE on here HAS done it so maybe they can inform us.
Old 01-27-2008, 11:44 AM   #6 (permalink)
Member # 95698
no i ment the tracker radiator. and the tracker has a belt driven fan with a clutch in it which i was thinking i'll just use the samurai fan if it will bolt up. also the speedo will work using the sammi trans it will have the cable driven speedo. i think i'm going to use the 1.3 trans because even with the 1.6 i'll have to still get the flywheel machined. thanks for the input. keep it coming.
Old 01-27-2008, 01:55 PM   #7 (permalink)
OKIE ZUK's Avatar
Member # 14812
Where are you getting your info? I too am doing a 2.0 but in a buggy. I think your getting some wrong info. Do more research. As stated contact Sean DeVinney, as his 2.0 in a stock bodied Zuk flew at the 2006 Melt.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
Old 01-27-2008, 09:27 PM   #8 (permalink)
Member # 106586
http://members.cox.net/aftermarket4x...es/2liter4.jpg
That's the 2.0 L which is basically the same configuration as the 1.8 L that I have in my back yard right now. Neither one have a belt driven fan with clutch.
The 1.6 has a belt driven fan with clutch and you can bolt the samurai 1.3L fan right up to the 1.6L if you don't have the fan that came with the 1.6.
http://members.cox.net/aftermarket4x...tracker16v.jpg
that's the 1.6L
Old 01-27-2008, 09:53 PM   #9 (permalink)
Member # 38172
Send a message via AIM to Shadow Crawlers Send a message via MSN to Shadow Crawlers
I know for a fact the 2.0l's have an engine driven fan.
Shadow Crawlers is online now   Reply With Quote
Old 01-28-2008, 05:55 PM   #10 (permalink)
Member # 20888
I know mine does.
cj_zuki is offline   Reply With Quote
Old 01-30-2008, 12:57 PM   #11 (permalink)
Member # 106586
Did some searching and it looks like some of the 2.0L engines have a fan bolted to the tensioner pully between the crank and the alternator. I don't know if the samurai fan will bolt to it or not. Why don't you just use the tracker fan? As far as air flow, it may not be the best, but I'd think that the draw from a mechanical fan should be able to cool the engine with the stock radiator. Unless you were sitting in traffic, or in the desert. Don't hold me to that though, as far as I knew they didn't even have mechanical fans.
Old 01-30-2008, 03:55 PM   #12 (permalink)
tdavis's Avatar
Member # 908
1) the mechanical fan is in the wrong place, and distance from the engine to work in a zuk with the stock shroud and radiator.
2) the 2 liter runs way hotter than the 1.3, so you will need a bigger radiator.
3) look here for more 2 liter information.
I take my zuk out for walks.
tdavis is offline   Reply With Quote
Old 01-31-2008, 12:29 PM   #13 (permalink)
Member # 38172
Speaking of radiators I recall that you were using a scirrocco (spell check) radiator. I don't remember seeing a part number? I'd like to check into one of these .
Thanks
Old 01-31-2008, 02:01 PM   #14 (permalink)
tdavis's Avatar
Member # 908
Thanks
I dunno remember, I'd have to do some digging - it's the same radiator in the tukizuki.
It does one heck of a job keeping it cool; I get temps in the 120's out of it doing 60..
Old 02-01-2008, 05:19 AM   #15 (permalink)
Member # 95698
what info that i have seems to be wrong?
Old 02-01-2008, 04:38 PM   #16 (permalink)
OKIE ZUK's Avatar
Member # 14812
Samurai speedo is in the t-case, not the trans. With the 1.6 you use a stock Samurai flywheel.
Old 02-09-2008, 04:01 PM   #17 (permalink)
Member # 95698
sorry it been a while since i checked on this. but i think that we are on two separte pages. so what your saying is with the 2.0 motor and the 1.6 trans i would just use the samurai flywheel and have no problem? i planned on get this swap under way this weekend but i want to get at least one last hell run in before i do. also there is a bunch of people going out next sunday so i think it is going to get put off till then.
Old 02-10-2008, 09:10 AM   #18 (permalink)
Member # 106586
no, the 1.6 uses the stock flywheel, Irish was saying you wouldn't need it machined. The 2.0 uses a custom flywheel to mate with the samurai transmission.
Old 02-12-2008, 08:25 AM   #19 (permalink)
Member # 17999
from what i have read i don't need the pressure sensor. with out it it will just have a check engine light. as far as the speed sensor i thought of it but i don't think it is really needed. what do you mean by the speed sensor from the kick speedo? this motor came out of a tracker. jump in. keep it coming.
OK... IF you aren't concerned about passing smog... then the pressure sensor isn't necessary as this is for the EVAP system. However there is the crank timing sensor on the engine and the VSS in the track/kick instrument cluster that is crucial to the proper timing and performance of the engine. Be sure to do all the research necessary. There are plenty of resources available.
Have fun with this!
billybob_CA is offline   Reply With Quote
Old 02-12-2008, 08:47 AM   #20 (permalink)
Member # 95698
thats why i posted this up before getting in 2 deep. thanks for all the info so far. here is how far i got this weekend got the motor out, all wiring, and the dash. i also plan on making a stainless dash to mount the 2.0 cluster in.
you know i had to post this one since the 2.0 doesn't have a fan...
Old 02-12-2008, 12:10 PM   #21 (permalink)
Member # 95698
so many views so little replies.
Old 02-12-2008, 04:19 PM   #22 (permalink)
Member # 104783
will do the 2.0 upgrade this summer. wireing is a byitch
08 resolutions: work less, screw wife longer
tommbstone is offline   Reply With Quote
Old 02-12-2008, 05:37 PM   #23 (permalink)
Member # 106586
everyone is trying to figure out how you got that fan to look like it was mounted on the front like that.
Old 02-12-2008, 07:26 PM   #24 (permalink)
Member # 25964
Keep the info coming. I want to do this at some point also. Are you going to do the wiring harness modifications or send it out?
What is the engine year availability for the 2.0 - just 1999-2002? (I'm going by Trail Toughs website ad for the 2.0 conversion)
lebowski is offline   Reply With Quote
Old 02-13-2008, 06:48 PM   #25 (permalink)
Member # 95698
yes all the wiring i'm going to do myself. as far as the motor mount and the flywheel i'm going to buy them.
