yj springs WHAT SIZE TIRES???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-29-2008, 03:17 PM   #1 (permalink)
suzukiwarrior's Avatar
Member # 18912
Send a message via AIM to suzukiwarrior
I Have 91 Suzuki With 33 I Want To Do The Yj Set Up On It ...so What Size Tires Can I Fit With Stock Yj Springs????
YES I drive a Samurai...you WILL outrun me....BUT you WON'T follow me! 1992 suzuki 33"bfg locked 6to1 t case
1988 mazuk 36" swampers mazde rx7 power 105 inch w/bhttp://katkins.web.aplus.net/sitebuildercontent/sitebuilderpictures/demo.gif
suzukiwarrior is offline   Reply With Quote Quick reply to this message
Old 01-29-2008, 03:22 PM   #2 (permalink)
Mall Crawler
Edisonsteve's Avatar
Member # 46928
Send a message via Yahoo to Edisonsteve
33" with stock yj's and still need to trim the front fenders.
1994 Toyota Extra cab, Exo, SAS, Linked, Kings, Air Bumps, 60s, 5.38, Detroit/Detroit, 40"MTR, Supercharged 3.4 5vz V6, A340F Auto Trans Manual shift, Atlas 4.3 4spd, Winch front and rear. CA smog legal and DD
2012 Jeep Sahara Unlimmited 4" lift 5.13 37s
2005 Dodge 2500HD Cummins 4x4 35s
Edisonsteve is offline   Reply With Quote Quick reply to this message
Old 01-29-2008, 04:59 PM   #3 (permalink)
Member # 50855
I run 31x13.5 tires and dont think I could go bigger without making more room.
Red Rocket is offline   Reply With Quote Quick reply to this message
Old 01-29-2008, 05:16 PM   #4 (permalink)
Member # 18912
Or What Do I Have To Do To Keep The 33 On It ??????????
Old 01-29-2008, 05:25 PM   #5 (permalink)
Member # 26165
Send a message via Yahoo to zukibrothers
as has already been posted. 33's will fit fine with spoa yj's.
True procrastionation is the art of putting a task off until it doesn't need to be done anymore.
zukibrothers is offline   Reply With Quote Quick reply to this message
Old 01-29-2008, 06:15 PM   #6 (permalink)
Mall Crawler
Member # 46928
I run 32" with Trail Gear YJ springs with 2 1/2" of up travel. At full stuff all twisted up I can touch the fender in the front. If I had any more up travel I would have to trim
Old 01-29-2008, 06:23 PM   #7 (permalink)
moveaside's Avatar
Member # 11983
33's will make your ass look fat I would not recommend them
My crappy build
moveaside is offline   Reply With Quote Quick reply to this message
Old 01-29-2008, 06:39 PM   #8 (permalink)
lockman's Avatar
Member # 25700
Send a message via Yahoo to lockman
Pictures speak for themselves. Sky's YJ kit, stock YJ springs. Axle moved forward 1". 34" LTB's 2.5" backspace. Just trimmed the front corner of the wheelwell and cleared cust fine.
lockman is offline   Reply With Quote Quick reply to this message
Old 01-29-2008, 06:58 PM   #9 (permalink)
Member # 17632
You can run 35s if you trim your front fenders for steering clearance. Otherwise, 33s will be fine with minimal trim.
Travis..
'15 Ram 2500 4x4 Big C and a 6 speed
2000 TJ on 35's
crashnzuk is offline   Reply With Quote Quick reply to this message
Old 01-30-2008, 12:37 AM   #10 (permalink)
Member # 86289
My buddy runs the TT YJ kit on Dana 44's and 35x12.5" Goodyear MTR's and just a little fender trimming, also has TJ fender flares on.
By the way Edisonsteve,
Do you actually work at Edison? I work at Edison's Midway Sunset co-gen plant. Just wanted to know, thanks.
Grind is offline   Reply With Quote Quick reply to this message
Old 01-30-2008, 06:20 AM   #11 (permalink)
Mall Crawler
Member # 46928
Yes I work for Edison. Lineman for 12 years , Electrical Service Planner for 11 now. Been at a few service centers over the years. Santa Fe Springs now.
Old 01-30-2008, 07:46 AM   #12 (permalink)
Member # 88667
Send a message via MSN to LostZuk
There are 38's with no front fenders and some trimming in the rear.
I do not have a problem with insanity, I am quite comfortable with mine!
LostZuk is offline   Reply With Quote Quick reply to this message
Old 01-30-2008, 01:40 PM   #13 (permalink)
Member # 86289
Right on man, sry every body for the thread hijack for a minute there.
Lost are you runnin' YJ's? Kinda looks like 2.5" wide but I'm not sure.
Old 01-31-2008, 07:44 AM   #14 (permalink)
Member # 101265
I "think" Lost Soul is running rears up front, but it should be similar to the YJs in height.
Kunker is offline   Reply With Quote Quick reply to this message
Old 01-31-2008, 12:37 PM   #15 (permalink)
Member # 88667
Those are 5 Packs YJ front and 4 Pack YJ rear. I am going to swap the rears to 5 Pack.
Old 02-01-2008, 12:42 PM   #16 (permalink)
Member # 18912
thank you for the info
