yota axles/ hydro ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-02-2008, 12:35 AM   #1 (permalink)
Member # 68882
yota axles/ hydro ?
im just wondering on yota axles , is it best to use a 6in ram or 8 in. I dont want to rip the knuckles off so im thinkin a 6 in but i also want to get the best turn radius as posible ... any input woudl be great
hooliganZUK is offline   Reply With Quote
Old 02-02-2008, 02:31 AM   #2 (permalink)
SMASHurai
toykilla5150's Avatar
Member # 65463
Send a message via AIM to toykilla5150
The best way is to measure ur steering travel at the tie rod (if that's what ur going to mount it to) measure from full turn left to full right. That will tell you ur min. ram travel needed from lock to lock. What kind of setup are u runnin? leaves? linked? I'm running a 6" and its to short with my linked setup. With links and longfields u can get upto 45 degrees of steering if you can get everthing to clear and a long travel ram.
you cant fix stupid people
87 zuk- modded/wheeler/DD
86 zuk- tub/registered propane
88 zuk- firewall/last rig
87 zuk- invisable w/title
toykilla5150 is offline   Reply With Quote
Old 02-02-2008, 08:17 AM   #3 (permalink)
POWERSTROKEN's Avatar
Member # 40246
Send a message via AIM to POWERSTROKEN Send a message via Yahoo to POWERSTROKEN
Someone like PSC can custom adjust a larger ram to less travel for you, they did mine. You will run the risk of ripping the knuckles off the housing if you go to big and arent careful. With full hydro its hard to "feel" the steering. Jim
[SIZE="3"]"Don't RAM it...STROKE it" [COLOR="DarkRed"] Family Krawler 98 4 door Tracker in the works CPI 4.3, 700R4, MC Dual Ultimate Toy's, Rockwell's, Fox air shocks[/COLOR] [COLOR="Navy"]2000 E350 4x4 7.3 Powerstroke D60/D70 35" IROK's on 20" Trail Ready's, Powershot 2000, Edge Evolution programer [/COLOR] [/SIZE]
POWERSTROKEN is offline   Reply With Quote
Old 02-02-2008, 09:48 AM   #4 (permalink)
Member # 68882
im runnin a three link set up w/ a panhard, and a coil set it works well , im just streching the wheel base to about 100in now so my sidekick power steering has got to go,
Old 02-03-2008, 07:05 PM   #5 (permalink)
OKIE ZUK's Avatar
Member # 14812
Use an 8" stroke ram and limit it yourself. A Jeep and Zuk I built, notice limits against the rod ends. No matter what ram you use, it'll need to be fine tuned to keep from ripping the knuckles off.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote
Old 02-03-2008, 07:09 PM   #6 (permalink)
OKIE ZUK's Avatar
Member # 14812
Oh and I built both of these with a three link setup w/a panhard.
Old 02-03-2008, 07:32 PM   #7 (permalink)
Member # 68882
im going to run a single end ram 8in and just limit it like you said and I know all you guys say to go with the double ended but i just dont have the cash right know.. but thanks for all the info
Old 02-03-2008, 07:56 PM   #8 (permalink)
OKIE ZUK's Avatar
Member # 14812
Surplus center, $189.00 double ended and $69.00 single. Here's a $69.00 one I used on a build, sorry hard to see.
Old 02-03-2008, 08:31 PM   #9 (permalink)
OKIE ZUK's Avatar
Member # 14812
After building several Toy front axle setups, high steer arms come in different lengths. So throws will vary.
Old 02-04-2008, 02:42 PM   #10 (permalink)
Member # 40246
Anyone arms you like better than anothers for the double ended ram setup? I had 4x4labs on golddigger but I never installed the ram. Jim
Old 02-04-2008, 02:46 PM   #11 (permalink)
Member # 40246
I forgot all about this. I have a New never used ram and mount kit with lines I bought from PSC for my Toy axle, It's a single endedram. I sent it to someone who kept it for a year and painted it orange I believe? (ive yet to remove it from the package) and return it to me because they couldnt afford it Its for sale if you are interested? I could have returned it for a refund before I was jerked off. Now it just sits here in a box. Jim
Old 02-04-2008, 05:08 PM   #12 (permalink)
Member # 68882
pm'd you
