Member # 81232
2wd t-case plus 4wd t-case?
If I stretch out my wheelbas from stock, mount a fuel cell in the bed of my sammi to eliminate the tank underneath, would it be possible or feasible to mate a 2wd sammi transfercase to a 4wd sammi transfer case. the stock 2wd case has the standard 1.8:1 (or whatever it is) reduction for high range and my current 4wd t-case has 4:1 gears. If I doubled them up, I should have about a 7:1 reduction which I hope will be enough gearing along with stock yota 4.10's to turn 35-36" tires in the rocks. I know the case would need to be really well supported and reinforced. wadda ya think?
Member # 63309
its gonna look ghetto as hell with driveshafts going from case to case all croked because of the offsets, but there is no reason it wouldent work.theres just WAY better ways to go about doing this
Member # 24273
Isn't the stock t-case 1:1 in high range?
Edit... just found it... it's 1.41:1
gunracer1- You must have the reading comprehension of a first graded Last edited by jerseyzuks; 02-03-2008 at 01:46 PM. |
Member # 14812
1.8 = Track/Kick
1.41 = Sami
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc. |
Member # 24273
That's a lot of work for a 5.6:1 reduction
Sell the 4:1 and the stock case, buy a 6.4:1 case
gunracer1- You must have the reading comprehension of a first graded |
