Venting t-cases and Axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-05-2002, 12:48 PM   #1 (permalink)
NC Zuk's Avatar
Member # 12060
Send a message via Yahoo to NC Zuk
Question Venting t-cases and Axles
I have seen a few people that have vent extensions on their axles as well as their t-cases and I have some on the way with my coil suspension. I understand the concept but wonder if any of you have suffered the consequences for not having extensions. Does it really have that much of a benefit? I'm all ears......................
RIP MSG Art Lilley, you will never be forgotten...
NC Zuk is offline   Reply With Quote
Old 07-05-2002, 01:43 PM   #2 (permalink)
HSE, Inc.
Hank's Avatar
Member # 11311
Send a message via Yahoo to Hank
I learned the hard way with my Chevy Truck. Deep mud/water. When I checked the diff, it ran out the check hole forever. Luckily it didn't ruin anything. Since then, I have routed them high on all my trucks.
I did the T-case on the Sammi yesterday. I'm waiting to do the rear until I get my new shackles installed. I have to see it flex before I run the hose to that one!
Hank is offline   Reply With Quote
Old 07-05-2002, 11:32 PM   #3 (permalink)
Member # 10487
vent.....won't go without them.....
Down here we play alot in water so its almost mandatory to vent all the stuff.....
I use 1/2" heater hose and connected both and them routed the hose in the dash through the firewall...(when oil comes out of the dash, its a good indication I'm upside down.....)I did my tranny(did this one when I had it off) and T-case.
Don't forget the shift boots, they suck in water too.....
92 Samurai, SPOA, 31" boggers, snorkel, 8274 Warn winch......and MOTOR MISSING ONE PISTON
zukimoo is offline   Reply With Quote
Old 07-06-2002, 07:45 AM   #4 (permalink)
Member # 12480
If you put a trap in the tubing coming out of the axles, etc. when (not IF) you roll over it will be harder for the fluid to leak out.
BTW it's a PIA to get a hose onto the t-case & tranny.
Wyld Bill is offline   Reply With Quote
