6.1 install ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-08-2002, 10:34 AM   #1 (permalink)
ROCKILLER's Avatar
Member # 3273
6.1 install ?
OK I went to pull my case apart yesterday to put the gears in and I cant get the thing apart. I took off the smaller piece with the rear output and then removed the roll pin and that fork that it hold on but I must be missing something because the case will only come apart 1/2 an inch. Also is there a difference between efi and non efi cases. I hace an efi case that has a broken cover and a non efi case with broken insides.
[QUOTE=Alfred W.;10665950]When a man has the scent of pussy in his nose...... The best advice in the world bounces off the block formerly know as his head. :grinpimp:[/QUOTE]
ROCKILLER is offline   Reply With Quote
Old 07-08-2002, 11:32 AM   #2 (permalink)
Member # 7606
If all the bolts are out and the tcase won't separate, it sounds like the speedo drive might still be in there. The instructions should go over this. Pull that speedo drive out and you can likely just tap the case halves apart.
Rocky Road is offline   Reply With Quote
Old 07-08-2002, 12:07 PM   #3 (permalink)
Member # 2752
Don't you have to pull the detent balls out forst too (I forget)??
By the way Glenn, thanks for e-mailing me those instructions. I got mine done this weekend
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
