Phatmobile - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-10-2002, 07:44 PM   #1 (permalink)
fatkid's Avatar
Member # 4862
Phatmobile
Here are some pics of the some of the new tube work.
From the side we gained about 3" over all in body length.
[url]http://www.myspace.com/jerrywsparks[/url]
fatkid is offline   Reply With Quote
Old 07-10-2002, 07:47 PM   #2 (permalink)
fatkid's Avatar
Member # 4862
Rear shocks are Bilstiens and the its been narrowed about 18"
The majority of the tube is 2"x.120 and we reused the stock fuel tank, not to mention we reused the stock filler neck.
Old 07-10-2002, 07:47 PM   #3 (permalink)
fatkid's Avatar
Member # 4862
Pic of the rear shock hoop
Old 07-10-2002, 07:50 PM   #4 (permalink)
fatkid's Avatar
Member # 4862
From the front you can see we narrowed the body by about 13"
We also did away with the Rocksliders and did a tappered rock pannle that works as a slider.
Old 07-10-2002, 07:52 PM   #5 (permalink)
Chubby Chaser
Mustard Dog's Avatar
Member # 7889
Send a message via AIM to Mustard Dog
That thing looks PHAT dawg
Eric Anderson
TIN BENDERS
Hendrix XR Chassis #001
Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS
Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse.
Accepting the things I cannot change.
Mustard Dog is offline   Reply With Quote
Old 07-10-2002, 07:53 PM   #6 (permalink)
High5's Avatar
Member # 1700
man that looks sweet!!!! and apparently it works good too! i do think it would look better if the white side pannels came up and angled down and followed the lines of the tube beside the seats on each side. just my op though. what springs do you run? yj's? do you have a front on view? do run a shackle reversal in the front?thanks.
High5
IT'S 1TON O' FUN!
High5 is offline   Reply With Quote
Old 07-10-2002, 07:54 PM   #7 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
That sure has changed a lot since TDS! Looks
Originally Posted by fatdan460 View Post
it leads to real abuse, like guys who will smack a broad in the head
For Sale!! F150 5x135mm wheels!!
Wanted, Ak parts, kits or whole rifles!
Gozuki is offline   Reply With Quote
Old 07-10-2002, 07:57 PM   #8 (permalink)
fatkid's Avatar
Member # 4862
The body pannles are kind of a first, there made to be changed quick and cheap. It wouldn't take much to change any of the body work.
The rear springs are 3" XJ's put on backwards so that they off set the rear center pin by 4" and the front has Yj's.
Old 07-10-2002, 07:58 PM   #9 (permalink)
Member # 977
Looks really good. How do you feel about the way it all worked?
eXtreme web-wheeler!
scwafish is offline   Reply With Quote
Old 07-10-2002, 08:23 PM   #10 (permalink)
fatkid's Avatar
Member # 4862
Worked well, needs deaper gears and some tires. As for the suspension and the wheel base I think I'm going to run it for a while and see. No changes come to mind as of yet.
Old 07-10-2002, 08:46 PM   #11 (permalink)
Member # 5821
fatkid, I saw you up at the litl sluce and you rig looks great. I was talking to the guy that drives the shafer rig Mike I think and he told me all about it. Nice work, I am new to the samy thing but very old to the fab thing and yours turned out real nice! Have fun!
Rokcrln.
Buildem--Rollem--Tearem Apart--Get Rid of the Wife--And Start All Over!
BRONCO BUGGY; dana44,35spln 9", 37's, 351W efi, C5full manual w/comp brk, atlass 5:1, fox 16" air's master craft rubicon's, full hydro, and a girl friend that loves to help.
rokcrln is offline   Reply With Quote
Old 07-10-2002, 08:52 PM   #12 (permalink)
fatkid's Avatar
Member # 4862
thanks Did you see me go through Lil Sluice, it wasn't pretty.
Old 07-10-2002, 09:00 PM   #13 (permalink)
RE:Todd's Avatar
Member # 422
Cool
Rig looks great Fattie .
Did you flop it in the box??
Todd Steele
TINBENDERS
Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper.
[url=http://www.tinbenders.org]TinBenders.org[/url]
RE:Todd is offline   Reply With Quote
Old 07-10-2002, 09:04 PM   #14 (permalink)
fatkid's Avatar
Member # 4862
No, the box was really chewed up and the lil 33"s where just getting swallowed! I ran it but it wasn't smooth.
Old 07-10-2002, 10:12 PM   #15 (permalink)
Member # 5821
Fatkid don't worry I saw you and I assume it wasn't your best but keep in mind that Lance went in and did not come out in his normal cat walk time eather. I pulled up and just parked after checking it out real well then decided to just build a rig like schafers to play with rather then bust up the EB.
Old 07-10-2002, 10:29 PM   #16 (permalink)
Member # 6891
Man that thing is looking great! What are you thinking about doing for gears? How well did the xj springs flex?
88 sammi,coiled,toy axles,hydraulic steering,5.29's,spools,longfields,grs2,RCI seats,37" boggers,hy-steer,4-wheel discs,and some trimmin
nuttzack is offline   Reply With Quote
Old 07-10-2002, 10:58 PM   #17 (permalink)
RocKrawler's Avatar
Member # 416
Everyone's overlooking the big question... how do you make mud flaps look good on that thang?
RocKrawler is offline   Reply With Quote
Old 07-10-2002, 11:26 PM   #18 (permalink)
fatkid's Avatar
Member # 4862
I want to put it back on the street, if we do were thinking of using half of one of those kidie pools for each of the tires.
Old 07-10-2002, 11:38 PM   #19 (permalink)
fatkid's Avatar
Member # 4862
We've got some extra special stuff on schedual for the gearing, however it's top secrete until it's done.
As for the Suspension, it's trick! The XJ's flex like mad with the springs inboard, almost to much so we had to change the springs to 3" lift springs with the clamps still on. We also had use a really awsome shock (Bilstien 5100 Coilovers) in order to get rid of the masive body roll. With the Bilstiens and the inboard springs it flexs well ( @1100 on a 27*) but is still stable enough to side hill. We feel that it's set up well for a variety of wheeling.
Old 07-10-2002, 11:39 PM   #20 (permalink)
RocKrawler's Avatar
Member # 416
use those old corregated galvanized trash cans as flares and the lids as hub caps SHINEY!
Old 07-11-2002, 02:37 AM   #21 (permalink)
Member # 3621
do i smell toy cases? what meats are you gonna stick under it? more pics
poppycock is offline   Reply With Quote
Old 07-11-2002, 06:16 AM   #22 (permalink)
zuk88's Avatar
Member # 3785
Looks great Fatty Your takin' that to SOR right? I need a closer look at the awsome tube work.
[B]'88 ZUK[/B]
Toy axles,4.30 r&p, spool rear, EZ front,4.16 t-case, 2" YJs, Sky Mfg hy-steer, 33" thorns, and fuzzy seat covers.
zuk88 is offline   Reply With Quote
Old 07-11-2002, 06:20 AM   #23 (permalink)
Azrckcrawler's Avatar
Member # 3550
Looks good. Almost makes me want to stay leafs all around. I assume the XJ's are the same length as the YJ's? I need some new springs and it's getting real hard to find stock YJ's anymore now that everyone is buying TJ's and lifting them.
[URL="http://www.azrockcrawler.com/_images/btgdvd/btgvol4dvd/btgvol4dvd.html"]Built to Grind 4 DVD - 2 Hours of Arizona and NM Rockcrawling
[/URL]
Chassis Plans for the Do-It-Yourselfer
[URL="http://www.azrockcrawler.com"]www.azrockcrawler.com[/URL]
BTG Rockcrawlers
Azrckcrawler is offline   Reply With Quote
Old 07-11-2002, 08:04 AM   #24 (permalink)
Member # 5832
how do you get the beer cooler out?
UZI 9mm is offline   Reply With Quote
Old 07-11-2002, 08:26 AM   #25 (permalink)
JackA's Avatar
Member # 2129
Looks good. See ya at the Hammers in a few weeks?
JackA is offline   Reply With Quote
