Hard top zuk roll cage design - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-31-2008, 05:22 PM   #1 (permalink)
Member # 94795
Send a message via MSN to Lil_Toy_Zuk
here is the pic tell me what you think im sure id add gussets to the corners for extra strength but i was looking for minimal weight gain with the exo cage
87 Zuk HT New built Motor(10:1 comp hawks billet stage 2 cam swift head)
35" boggers (PNW special), TG 6.5 gears Are in, got subie MC (this list getting long)
Lil_Toy_Zuk is offline   Reply With Quote Quick reply to this message
Old 08-31-2008, 06:05 PM   #2 (permalink)
onewhitezj's Avatar
Member # 45304
what is the front to back going to look like?
onewhitezj is offline   Reply With Quote Quick reply to this message
Old 08-31-2008, 06:32 PM   #3 (permalink)
Member # 94795
ill draw it up soon and put it on here
Old 08-31-2008, 08:40 PM   #4 (permalink)
OKIE ZUK's Avatar
Member # 14812
In the near future I'll be exo caging a couple of tin tops. I'll post pix.
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote Quick reply to this message
Old 08-31-2008, 10:04 PM   #5 (permalink)
Member # 94795
right on i look forward to seeing more ideas im just not too impressed with most out there just a waste of metal on some id rather see a cage that adds minimal weight but provides good protection. i just started drawing up the rear ill post it soon
Old 09-01-2008, 07:17 AM   #6 (permalink)
Member # 38172
Send a message via AIM to Shadow Crawlers Send a message via MSN to Shadow Crawlers
I use HREW on my cages but if I was to exo a hardtop and not be able to x brace I would go with DOM at the mininum .
Shadow Crawlers is offline   Reply With Quote Quick reply to this message
Old 09-01-2008, 08:02 AM   #7 (permalink)
Member # 6895
Subscribed as well.
Spankbomb is offline   Reply With Quote Quick reply to this message
Old 09-01-2008, 05:11 PM   #8 (permalink)
Member # 94795
here is the back im thinking that ill connect through the body for the side or maybe go down to the frame on it not sure just a general design still i need to make the top view and front also the hidden line tapering in toward body under door and out behind front tire and in front of back tire hard to understand but ill draw more so you can see
Old 09-01-2008, 06:27 PM   #9 (permalink)
Member # 94795
btw this isnt a build thread just looking for criticism or points that i might be missing. Or maybe you want to show your ideas, im sure alot of you out there have some good ideas of your own what ever helps thanks
Old 09-02-2008, 01:11 AM   #10 (permalink)
OKIE ZUK's Avatar
Member # 14812
I saved pix of this one and also check out Blueballls rig.
Old 09-02-2008, 09:10 AM   #11 (permalink)
Member # 106586
I think if you lengthened your bottom rocker and dropped the center side brace straight down, you would have a stronger vertical brace if you get inverted, but the angled brace you designed provides better latteral bracing if you dump it on it's ass. Not sure yet where the cross braces attach, but you definitely will need them or it would just fold on you in a side roll. It looks sharp though, maybe a perspective view would be good for visualization of some of the cross bracing.
You can only smell fear if the fearfull have loose bowels.
Baratacus is offline   Reply With Quote Quick reply to this message
Old 09-02-2008, 09:22 AM   #12 (permalink)
Member # 94795
i really like that pic okie do you have a back view of it. nice sami really straight body.
Baratacus i was thinking a simmilar thing also but was thinking that if i have a tube running straight down in front and behind door which would be good points for tube doors also
Old 09-02-2008, 03:36 PM   #13 (permalink)
Member # 8111
Here are few for you
Your right I own the Fucking Place
All Rock 4X Fab Products Made IN THE USA!!!
Rock 4X Fabrication,Inc 1-847-544.1823
Rockrat is offline   Reply With Quote Quick reply to this message
Old 09-02-2008, 05:11 PM   #14 (permalink)
Member # 20457
Send a message via Yahoo to norzuki
Originally Posted by lil_toy_zuk View Post
i Really Like That Pic Okie Do You Have A Back View Of It. Nice Sami Really Straight Body.
X 2
America Lost a Hero.............I lost a Best Friend !!
At-ease soldier ... mission complete
norzuki is offline   Reply With Quote Quick reply to this message
Old 09-03-2008, 04:57 PM   #15 (permalink)
moveaside's Avatar
Member # 11983
Thumbs up
Right on man this is the single most bypassed step in a build and that is protection agianst dying. Not to mention there are some decent parts and pieces in there that are more likely to live with a cage protecting them too. Your design seems pretty straight forward.
My crappy build
moveaside is offline   Reply With Quote Quick reply to this message
Old 09-03-2008, 06:12 PM   #16 (permalink)
Member # 47313
where can i get a .dwg file like that for a soft top??
zuk - spua, 33 claws, TG 6.5s, ARBs, TT disconnect, 6pt
dee201 is offline   Reply With Quote Quick reply to this message
Old 09-03-2008, 07:16 PM   #17 (permalink)
Member # 94795
all i did was import a side pic of the sami and scaled it to size then followed the lines.
Just get a refrence points to scale the pic and trace the out side of it and add the body lines and windows a good tip for it is use the circle command and then 3 point, trim the excess and there you go
Old 09-03-2008, 09:09 PM   #18 (permalink)
Member # 47313
ahh ok i thought there may have been a top/front/side block somewhere i could d/l...
If i was gunna go to that much trouble i'd probably just photoshop it. Cheers anyway.
