95 Samurai stock axles + 33 inches tires = ??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-22-2008, 05:45 PM   #1 (permalink)
Member # 47578
Send a message via MSN to guto_cerulli
Hi!!
I'm working on a new project, it means a 95 Samurai and I'm thinking on 33 inches tires using the stock axles, there is some here expirient on it?
thanks,
DD/"trail pig" - 98XJ - It's silver...
guto_cerulli is offline   Reply With Quote Quick reply to this message
Old 10-22-2008, 06:50 PM   #2 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
I sent you a PM regarding this topic, please check in after you do i'll delete this.
-jay
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
supazuk94 is offline   Reply With Quote Quick reply to this message
Old 10-22-2008, 06:58 PM   #3 (permalink)
Member # 105114
thats how the stockers will end and the clutch unless ur rly nice unlike me
This is our decision to live fast and die young, we've got the vision, now lets have some fun.
RATHEFSJMAN is offline   Reply With Quote Quick reply to this message
Old 10-23-2008, 05:38 PM   #4 (permalink)
AttemptingTJ's Avatar
Member # 63087
Send a message via AIM to AttemptingTJ
I have 33x10.5 tsl on stock axles both welded with 5.13's and I beat the fukk out of it, and they are still holding up
-Ben
87 zuk, lots of pipe, toy axles, yjs, 36" tsl's, wrx seats, 5gal cell.
AttemptingTJ is offline   Reply With Quote Quick reply to this message
Old 10-23-2008, 10:03 PM   #5 (permalink)
Member # 101301
Im running 33's on sami axles. But I threw in some 26 spline side gears and front axle shafts with birfield rings, and yukon 5.38 R&P. I have 4.16 in the transfer case and everything is holding up well, but I try to be pretty nice since I DD my sammi
peewee2 is offline   Reply With Quote Quick reply to this message
Old 10-23-2008, 10:19 PM   #6 (permalink)
zukkev's Avatar
Member # 105276
I ran 33" LTB's on mine for a couple years with no troubles; stock axle gears/ 6:1 T-case gears/ 'spooled' rear-open front......
'scored' a set of 33x14 Boggers at a swap meet, and two runs later I was swappin to Yota axles--twisted the rear housing between the perches!!!Anyhow, moral is don't put Boggers on if you expect the axles to live with 33's....
zukkev is offline   Reply With Quote Quick reply to this message
Old 10-23-2008, 11:00 PM   #7 (permalink)
turd-polish-a-go-go
LittleBlackSambo's Avatar
Member # 49404
33x13.35's, stock axles, 5.13's, 4.1's, lockers front and rear, tt 4130 shafts up front, 4 wheel discs, lots of extra steel welded on, 3 years and no "major" problems. i've replaced all the bearings after the first season. i also have a mountain of spares if i need 'em.
of course, i went with pay-as-you-go. if i had all the cash i sunk into the stockers up front, i would have done toys to begin with. cash flow just don't work that way with most (normal) samurai people.
if you go easy on the skinny pedal, avoid excessive wheel hop when the wheels are turned, and finesse your way through, they will hold up. if that is too much for you to worry about, junk 'em and go big. i'm just saying that they *can* work, but it depends on your intended use and driving style.
thanks for the compliment, but it's not a jeep.
LittleBlackSambo is offline   Reply With Quote Quick reply to this message
Old 10-27-2008, 08:11 PM   #8 (permalink)
Member # 56477
I had a tin top with 33" TSL's. When I went to that tire size I really started breaking shafts, fronts and rears. I had birfield rings and that just made it harder to get the axle peices out. 5.12:1 R&P, 4:1 t-case gears. I did wheel it hard though...
wheelin' without the ego or attitude
JEEP: hard as fuck
j2custom is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 08:05 AM   #9 (permalink)
Member # 7753
31's are about the limit of worry free on stock axles. 33's and heavy foot start breaking things right away. Been that way for the 12 years I been into zuks.
Slowzuki is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 08:16 AM   #10 (permalink)
zzukizilla's Avatar
Member # 111968
I just stepped up from 31 to 33's and I wheeled the crap out of it last weekend on some insane obsticles and had it in some stupid situations and didn't have any problems YET.
zzukizilla is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 06:21 PM   #11 (permalink)
Member # 67544
Send a message via Yahoo to martyman
your very lucky then, i ran 33's and snaped birf's every time i turned hard, chunked that crap and went toy's!
Sammy on Propane,36 SX's,98 Wheel base,6.5-1 t case, 5.29's YJ's,Shaved Toy's,Exo cage,warn 9000
martyman is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 07:30 PM   #12 (permalink)
tinbeater's Avatar
Member # 16547
X2. People that are running 33s with stock axles and dont break really are not wheelling. Hell I broke stock Toyota's birfeilds with 33s.
tinbeater is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 07:44 PM   #13 (permalink)
Member # 121255
I am running stock Toys with 38's and it's all good so far....
zukeman is offline   Reply With Quote Quick reply to this message
Old 10-28-2008, 08:27 PM   #14 (permalink)
Vermin's Avatar
Member # 6524
Hrmm.. some people have more luck than others. I can't find the pics of the front housing after pieces of gear shot through it - but I do have some pics of the rear. My most epic break - both front shafts, housing, locker and gears - rear short side, entire diff and gears - all at the same time - all on 33's. But then again, I've never been accused of taking it too easy..
Vermin is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 02:46 PM   #15 (permalink)
Member # 106586
if you do 33's make sure you have enough space to turn them without biting your leaf springs. Lots of people run them just fine with little to no modification to the axels. Only critical modification is offset wheels. If you don't get a 1" backspaced wheel or at least put in a wheel spacer, you're going to bite the spring when you turn hard. When you do that the tire is going to walk up inside your wheelwell snapping your axel and steering linkage.
If you're muddbogging you need a different setup than if you're rock crawling and a different set up if you like to race down sandwashes and jump it. Can't really make a good recommendation unless we know how you plan to drive it.
You can only smell fear if the fearfull have loose bowels.
Baratacus is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 02:48 PM   #16 (permalink)
Member # 7753
Just wait until you need to give some engine to get out of a bound up spot with the wheels turned. It'll happen.
I've heard of some mud guys with stock gears and no lockers living with 33's but they aren't really wheeling, more mall wheelers than wheelers.
Old 10-29-2008, 04:28 PM   #17 (permalink)
Member # 106586
Any time you bind the wheels up and have your lockers engaged you run the chance of tearing something. Especially if you have an overbuilt engine and a low geared T-case and or differential.
That brings us to another issue.
If you have the stock 1.3L engine and the stock transfer case and transmission, you're going to need to lower the gear ratio to turn these things. 5th gear is going to be completely useless to you and your engine will sound like an angry bee hive if you have to climb any kind of grade.
Old 10-29-2008, 05:39 PM   #18 (permalink)
purevil71's Avatar
Member # 9275
Send a message via Yahoo to purevil71
I wheeled four years on 33's with stock axles with no problems, and I'm sure if you ask around enough you'll find out that I do wheel (a little). I'm running Toy axles now, but only after I got my paws on a set of 36" Swampers.
Yes, your likely hood of breaking something goes up, but hell you can break a Rockwell if you try hard enough. There's a lot to be said for wheeling smart, and I fully believe you can wheel hard and smart at the same time and have a lot of fun doing it.
"Just when I think you've gone and said the stupidest thing ever, you keep on talking!"
___________________________________
'88.5 Sami buggy on 37's
'96 4-door Tracker on 35's
ZookiMelt FB Page:
purevil71 is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 05:58 PM   #19 (permalink)
Member # 63800
skinny 33s (33x9.5), open diffs, and 5.13s should take you a lot of places. * keep you foot off the go pedal.
*assuming you've got the clearance to turn and flex them. (offset wheels, spacers, lift, sawsall, etc.)
REAL QUESTION: have you tried wheeling it stock? where are front and rear lockers and aggresive tires not taking you?
"Im more flux-core than hard core." -- rustywagoneersdotcom
OffRoad is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 06:35 PM   #20 (permalink)
Member # 29177
I'm surprised that nobody has told him to sirch. When a forum loses it's edge, the baby jeebus cries
Blind Driver is offline   Reply With Quote Quick reply to this message
Old 10-29-2008, 07:23 PM   #21 (permalink)
purevil71's Avatar
Member # 9275
I thought he killed a kitten???
ZookiMelt FB Page:
Old 10-30-2008, 10:41 AM   #22 (permalink)
Member # 106586
Jesus and Kittens have nothing to do with a Samurai.... it's when the squirrels start dying that the shit hits the fan.
Good spelling and grammar are key when searching... unless the searcher has poor grammer and speaks the same dialect used in the post he's looking for. English isn't guto_cerulli's native language and its not real easy to find stuff with all the different english "Dialects" used around here...
It's not hard to find stuff on 33" tires though since just about everyone on here has run them at one time or another, but finding somthing about using them on stock equipment is a whole different furball.
Old 10-30-2008, 11:26 AM   #23 (permalink)
turd-polish-a-go-go
Member # 49404
Originally Posted by Baratacus View Post
...its not real easy to find stuff with all the different english "Dialects" used around here...
i think there is more of an issue with derelicts than with dialects...
Old 10-30-2008, 05:11 PM   #24 (permalink)
Member # 106586
agreed.
Old 10-31-2008, 02:18 PM   #25 (permalink)
Member # 77042
Haha... I'm on 33's, 6:1, 5.12's w/lockrite's and wheeled a bunch (heard of Rubicon?)... I have birfield rings up front, and take my time. The skinny usually stays out of the picture. I did break a short-side rear once... on flat ground...must have been waiting to break. I carried 4 spare axles. I'm sure it isn't invincible, but I let the engine idle up and over most obstacle's.. a little pedal when needed, but I'm in no hurry to spend an hour + to change a front shaft... the rears are fun (20min).
the biggest issue I have with the truck is rear axle wrap.. and that crappy Sky anti-wrap junk thing
Cheers!
MrSammi is offline   Reply With Quote Quick reply to this message
