T-Case Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-25-2008, 01:47 PM   #1 (permalink)
Member # 121649
T-Case Question
i have a stock sami 2wd transfer case. i was wondering if you could make it a 4wd t case by taking the tail shaft off and changing the innards. (i have a 4wd t case but the previous owner broke 6 bolts off inside it and my sami came with another t case (the 2wd one).
so the main question is. is there any difference between the 2wd and 4wd t case other than the shaft that goes to the front axle?
JoMoWheeler is offline   Reply With Quote
Old 10-25-2008, 01:51 PM   #2 (permalink)
Member # 48911
nah, just bolt on the front connect!!
well, just install the front connect components, shift rod, or whatever.
cajunsuzukispider is offline   Reply With Quote
Old 10-25-2008, 05:17 PM   #3 (permalink)
turd-polish-a-go-go
LittleBlackSambo's Avatar
Member # 49404
you could always tear into it and find out... and let the board know what you've learned.
thanks for the compliment, but it's not a jeep.
LittleBlackSambo is offline   Reply With Quote
Old 10-25-2008, 07:08 PM   #4 (permalink)
Member # 37690
Send a message via Yahoo to blackrider
2wd t-casenever heard of one
4.3 vortec/tbi,yota axles/dual cases,40's,
stauns,oba,4 linked,coilovers,zook tub
[COLOR="blue"][SIZE="3"][FONT="Comic Sans MS"]NotQuiteRight Wheelers[/FONT][/SIZE][/COLOR]
blackrider is offline   Reply With Quote
Old 10-25-2008, 10:34 PM   #5 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
yes 2wd samis had dummy cases and they were geared down in high as a 4wd but had no low or front out put
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.ruffstuffspecialties.com
www.zukeviltwin.com
www.polyperformance.com
www.DEEPWOODSEXTREME.com
www.trailtough.com
supazuk94 is offline   Reply With Quote
Old 10-26-2008, 01:28 PM   #6 (permalink)
Member # 112420
x2 on that. pics lot of pics.
sami-stine is offline   Reply With Quote
Old 10-26-2008, 04:59 PM   #7 (permalink)
Member # 106586
yeah, 2wd sami's are a rarity. Most of the ones that people find, they convert to 4WD. You may be able to find a collector that will buy that T-case for more than the cost of a new, complete 4wd T-case. Look for a buyer before you go and tear it open and reconfigure it.
You can only smell fear if the fearfull have loose bowels.
Baratacus is offline   Reply With Quote
Old 10-26-2008, 05:05 PM   #8 (permalink)
turd-polish-a-go-go
Member # 49404
sometimes, when i eat too much cheese and not enough fiber, i crap turds that look like chicken eggs, and are hard as rocks- but that is a rarity. will i be able to find a collector to buy my rare turds?
Old 10-27-2008, 05:49 PM   #9 (permalink)
Member # 48911
how much?
I've seen pics of the 2wd t-case, from what I remember they just lack (on exterior appearance) the front nose for the 4wd, and have instead a plate that covers it.
Old 10-27-2008, 06:06 PM   #10 (permalink)
Member # 121649
Originally Posted by cajunsuzukispider View Post
how much?
yeah thats all it looks like. i got a 2wd sami now and have the 4wd transfer case so i am going to put the front output shaft in it. i am unable to post pics of the build but i can e-mail them to someone if you all want to see what it takes. (i will be doing the swap probably wed or thursday of this week.)
Old 10-27-2008, 07:37 PM   #11 (permalink)
Member # 38563
I've got one of those uber rare 2wd transfer cases. If anyone feels like paying me for it, by all means, PM me
I certainly am not going to tear it apart to see what is inside so that you could convert it to a 4wd tcase. You may as well just install a 4wd tcase, they only made about a zillion of them...
95' 4Runner with 5VZ engine WTB...winch bumper
84' M1031 CUCV 37's, 8kW gen
Pietro is offline   Reply With Quote
Old 10-27-2008, 08:13 PM   #12 (permalink)
Member # 106586
If your turds got better gas mileage, and could flat tow behind an RV without the need for a drive shaft disconnect, you might be able to find a buyer. There are people out there that use the sami for a towed secondary ride for bumping around town or on mild trails that don't need or use 4wd. For them it would be just a big hassel. 2wd T-cases are less expensive, and more economical for someone like that. Just cause you have no use for it doesn't meen some excentric weirdo doesn' want it.
Old 10-27-2008, 09:16 PM   #13 (permalink)
turd-polish-a-go-go
Member # 49404
damn, good answer!
Old 10-28-2008, 11:31 AM   #14 (permalink)
Member # 14033
The 2wd output shaft is different and I believe the center gear cluster is different as well.
A 2wd tcase housing is the same as a 4wd, so it can be made into a 4wd tcase by changing the internal pieces that are different and adding the shift rod assemblies, shift rod/shifter housing and the shift lever.
97 Ranger D44 SAS/ARBs/4.56s/35s
87 Samurai "slightly" modified sleeper SPUA/33s/5.12s/KK3/EFI/LRs
skyhiranger is offline   Reply With Quote
Old 10-29-2008, 11:43 PM   #15 (permalink)
Member # 121649
Question Update
during my adventure i realized my t case is missing one of the ball bearings that go in the hole to put pressure against your shift fork. (not the large on that goes in the 4wd switch) there should be a total of 3 small ball bearings correct? one in the bottom with a spring. one in the middle between the two shift forks and one in the top with a spring. if anyone has one of these that would be great. if not if anyone knows where i can find them or the diameter of it (i really dont want to have to tear apart my t case to measure one.
i found that low range sells the larger one that goes in the 4wd switch dent ball but i need the smaller one.
pm me if you have any info i would very much appreciate it.
Old 10-30-2008, 06:12 AM   #16 (permalink)
Member # 14033
If it is the center detent ball that has been removed, it is because that allows you to access 2wd low by using an alternate shift pattern.
If it is one of the other detent balls that has been removed, just use the 2 you have for the outer ones and leave the center one out, that way you can access 2wd low.
There are a lot of people out there that have left the center detent ball out of the tcase (myself included), in order to have the 2wd low option and it doesn't affect the shifters staying in place (in my experience).
Old 10-30-2008, 06:48 AM   #17 (permalink)
Member # 99482
Send a message via AIM to samuraiguytn
Then you can get the "Evil Twins" Dual Tcase levers.
But if you need a 4 wheel drive Tcase, mine is for sale. http://bbs.zuwharrie.com/content/topic,90272.0.html
http://www.planet4x4.net/4x4Country/register.php?REF=2415 its an addictive game
samuraiguytn is offline   Reply With Quote
Old 10-31-2008, 11:40 AM   #18 (permalink)
bluzuk80's Avatar
Member # 122462
Hey samuraiguytn, how much boot would it take for me to trade u a stock low mileage case for yours with the t/c gears???
*UNDER CONSTRUCTION* Wide Open Design Revolution Built L33 alum 5.3/400/Atlas/HP60/14/ORIs/Reds/Trailreadys
2500 CTD 4x4 6spd tow rig
www.hawkpridemountainoffroad.com
www.wideopendesign.com
bluzuk80 is offline   Reply With Quote
Old 10-31-2008, 07:15 PM   #19 (permalink)
Member # 99482
Oh I dunno..............about 700
Actually, Im putting in full yota power & Drive-train So I have no use for the zuke stuff. However if you email Drake at www.tdoffroad.com and see if a stock Tcase would be useful to him....he may work out a deal with you. Cause thats were it is at. Im trading it to him for some labor, But he needs the cash more...
