Interesting Bead locks - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-14-2008, 06:43 AM   #1 (permalink)
Member # 20457
Send a message via Yahoo to norzuki
Forgive me if I am posting in the wrong section the Moderator can move if needed.
Has anyone seen the new bead locks on page 75 of the new CRAWL magazine?
I just went to their website www.innerairlock.com and they look very impressive !! The Stauns are cheaper, but I thought I would let everyone know about these also.
Dave
America Lost a Hero.............I lost a Best Friend !!
At-ease soldier ... mission complete
norzuki is offline   Reply With Quote
Old 11-14-2008, 07:16 AM   #2 (permalink)
Member # 70258
How are the Staun's cheaper? I haven't seen any for $450 a set. (4)
1987 Samurai 5.0/ 14 bolt/ hp60 welded with 38.5 sx's on h1's C6/1356/np205 108" wb
Jy Dog is offline   Reply With Quote
Old 11-14-2008, 07:24 AM   #3 (permalink)
jar73186's Avatar
Member # 77698
Talk to 91Blaze he runs them in both his xrra buggy and his mod stock yota. So far from what I have seen of them they work and they can hold up to his abuse.
Adam
www.Rubberbellyracing.com
jar73186 is offline   Reply With Quote
Old 11-14-2008, 07:37 AM   #4 (permalink)
Member # 21282
here's the installed reinforcement rings
[/quote]
also got em on my yota
this is the zoomed out view of the hill - it ended up all the way on the bottom from where the spotter is now
I've beat the hell out of the yota for over a year now with the airlocks and they have been great
I was worried that the tubes would blow after hard impacts and rolls but they haven't yet and I think it's been over 4-5 times hard this year
Team RockWild! - Racin for Fun!
Recommended Stuff: InnerAirlock - TrailerGuy
FOR SALE: 14,000 TOTER
91blaze is offline   Reply With Quote
Old 11-14-2008, 08:31 AM   #5 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
Dave
inner air locks are wayyyyyyy cheaper than stauns like 4 innerair locks for the price of 2 stauns
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.ruffstuffspecialties.com
www.zukeviltwin.com
www.polyperformance.com
www.DEEPWOODSEXTREME.com
www.trailtough.com
supazuk94 is offline   Reply With Quote
Old 11-14-2008, 08:41 AM   #6 (permalink)
Member # 48911
yeah, staun wants $200 per tire. screw that. when I told my local shop to put some bead-seal on my tire beads when they were installed, they said it'd be real hard to peel off to change tires. I had told them first that I'd use black RTV silicone to seal them on there and they told me that the tires would never come off if I did that.
well, it's been years, and they haven't leaked 1psi yet. but I haven't put them to the trail/4psi test yet. if silicone works so great, why not just use that, it'd only be like $10 to do all 4 tires.
cajunsuzukispider is offline   Reply With Quote
Old 11-14-2008, 09:11 AM   #7 (permalink)
Member # 21282
I've used roof tar, silicone and the DIY beadlock screws from inchworm and they all worked. Gluing the beads didn't turn out to be that bad to remove them.
the gluing process is messy but effective just not as effective as an actual mechanical beadlock device
the screw were ok too but they leaked and holes stripped out if you messed with the screws any. Not to mention I installed 286 screw total - not the end of the world but not convenient either.
All those have the disadvantage of not strengthing the rim edge. Neither do inner airlocks or stauns though and we've WADDED up 4 rims so far this year. 2 steel on the buggy and 2 aluminum on the toyota. Not a worry after the cool rim stiffeners on the buggy and I hope to get some AL ones for the toyota eventually.
Old 11-14-2008, 09:15 AM   #8 (permalink)
Member # 21282
Oh and we had problems with tires spinning on the rims (AL) so we had switched over to steel rims on everything. Then I got the airlocks and to save some weight went back to the AL rims. I was concerned that if I spun a tire it would destroy the airlocks, since the airlocks don't actually clamp the tire to the rim like a typical beadlock. Same rims, same situations, same wheel spin, not yet able to get a tire to rotate on the rim.
That should help with balancing since my road truck always ended up spun after talking it wheeling and the weight changed places with regards to the tire.
Old 11-14-2008, 10:04 AM   #9 (permalink)
Bigburlynakedguy's Avatar
Member # 11961
I use the Stauns on my race jeep and have gone 20 miles with no air in the tire from a broken rim. It took that long for the rim to finally cut the tube. I'm a fan.
Originally Posted by carwash View Post
maybe i'm just slow or retarded or something.
Bigburlynakedguy is offline   Reply With Quote
Old 11-15-2008, 01:22 PM   #10 (permalink)
Member # 53193
totally dig the bead locks, but that rock ring isn't so hot. you rub the ring into rocks for a while and I'll show you a nasty knife edge when you go to check your tire pressure. maybe I'm just a pussy.
2slo4u is offline   Reply With Quote
Old 11-15-2008, 02:39 PM   #11 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
I've ground my normal beadlocks pretty good on rocks and have yet to cut myself, or even scrape a knucle checking the air pressure.
Got a few friends running the Inner Air locks and they do great.
Here's a shot of their rim stiffeners
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 11-15-2008, 03:46 PM   #12 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
no need to check tire pressure after getting those
-UZI 9mm
thanks to:
www.zukeviltwin.com
www.trailtough.com
