Member # 105385
step 1: get a sawzall
step 2: cut step 3: curse.... a lot not sure. friend of mine plans to do this. i will find out if he started on it yet! would need some mo info. how much do you want to take the rear in? do you care if there is an inner fender? stock samurai? tintop?
Www.CottonlandCruisers.com 87 samurai 3sp auto/1.8 kick tcase/4:1 dana300, yota axles, 4 link rear, 39" krawlers.. reds 97 FZJ80 supersets,chromoly rear axles,4.88s , 345 KM2s |
Member # 115093
Thanks for the reply. Let me know how his went. I'll keep mine updated also. I'll post pics if someone could tell me how. Once was a tin top. Cut the top off, got a cage in it. Probably narrow 8". Can make new inner fender & floor with sheet metal.
Member # 105385
on zukikrawlers.com look up supazuk 4.0 for a very intense dove tail job.
This guy did starts out to: http://www.trail-gear.com/vbulletin/...ead.php?t=1709 ; Although it's more tubed than stocker :/
Member # 110178
I started mine a while ago. I got most of the cutting, lining up and reattaching the body back to the frame done in about a day and a half. I used a sawzall, aviation snips(a lot), a long steel ruler, a big square, drill motor and a couple hole saws, and a vice grip here or there for good measure. Basically I unbolted the rear of the tub. Made a large triangular cut in the center of the floor, Cut the leading edges of the wheel wells as well as the top bed rails if you could call them that as well as a couple relief cuts where they were needed. Then I pushed it all together and used sheet metal screws to hold it all together. Then with the hole saw I cut new holes for the body bolts just under the tailgate and bolted it back down. Now I'm redoing most of it as plans have changed (the whole floor and wheel wells will be going) and I have a TIG welder now so I can quit with the sheet metal screws already.
Member # 31144
The supazuk build isnt a dove tail... its a full tube back half... a dove tail is where your use the factory sheetmetal... and narrow it... Its been done so theres pics out there somewhere
88.5 Zuk, 1.6L 8v TBI, 6.5:1 Tcase, Dana 44's, Linked & Coiled, 102" wb, 9000XL's, 36" IROKS |
#10 (permalink) | |
Yup...
"Just when I think you've gone and said the stupidest thing ever, you keep on talking!" ___________________________________ '88.5 Sami buggy on 37's '96 4-door Tracker on 35's ZookiMelt FB Page: [url]http://www.facebook.com/profile.php?id=100003375889081[/url] |
Member # 11801
Shaffer's Offroad & Performance Phone (510)999-7766 1924 Willow St Alameda CA 94501 [url]www.Transfercaseexpress.com[/url] [url]www.Shaffersoffroad.com[/url] [url]www.Torchmateracing.com[/url] [url]www.Twitter.com/shaffersoffroad[/url] [url]www.Torchmate.com[/url] [url]www.Powertank.com[/url] |
#13 (permalink) | |
[URL="http://www.pirate4x4.com/forum/showthread.php?p=9122701#post9122701"]http://www.pirate4x4.com/forum/showthread.php?p=9122701#post9122701[/URL] [URL="http://www.facebook.com/#!/KentMatchell"]http://www.facebook.com/#!/KentMatchell[/URL] [URL="https://plus.google.com/u/0/108697912144062186544/posts"]https://plus.google.com/u/0/108697912144062186544/posts[/URL] |
#14 (permalink) |
Member # 24386
Wow, had to dig back to 2002 and find my pics on the ORC BBS.
I dig dove'd tubs, personally. Retains the look of the Sammy. ORC BBS thread on my dovetail
Yankee Tim www.rok-freekz.com Last edited by Yankee Tim; 11-26-2008 at 06:48 AM. Reason: Why, who's asking? |
#17 (permalink) |
#18 (permalink) |
Member # 89600
I wish I had those seats!! front half looks good the rear is like .......... well I cant think of a word for it!!
[URL="http://www.myspace.com/jasondonnel"]http://www.myspace.com/jasondonnel[/URL] |
