tail gate done - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-20-2008, 08:17 PM   #1 (permalink)
Member # 124133
tail gate done up date more done
on the 2 pic i put a 1/2 pipe around the lip . sow the tire wood not cut it
timmyc is offline   Reply With Quote Quick reply to this message
Old 12-20-2008, 09:37 PM   #2 (permalink)
Member # 17874
UHH...would you like a cookie now....
'89 zuk -locked toys- 37s- and stuff -lots of dents
why do i insist on rolling this thing?
tbone420 is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 05:50 AM   #3 (permalink)
Member # 124133
yes i wood
Old 12-21-2008, 06:29 AM   #4 (permalink)
Member # 48911
what kind of frame is that?
cajunsuzukispider is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 07:20 AM   #5 (permalink)
Member # 96029
Is that a eaton or 9inch axle?
Sami
slickrock209 is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 08:27 AM   #6 (permalink)
moveaside's Avatar
Member # 11983
Thats a 9 in baby he's got to have a bronco frame there. Timmy if you've noticed some of the guy's have been a little dickish to you. I'll sum it up for you. Some people like to bitch about anything but no one has a lust for rust. You really should wire wheel that frame to get a fresh start to the build. Especially if your going to be posting pics always remember people come here to learn not just to be coached into learning. Setting a "good builder's" example should be your motivation to do so. Yes coming from me I realize that is hypocrisy to some degree if you notice in any thread I do I disclaim some of my work and say "Do not copy".
On another note I'd like to say thanks for sharing your build here but try and keep the threads to stages or maybe even on the same thread. Everytime you finish one thing don't feel the need to start a new thread. In time there will be 3 pages of Timmy and nobody wants that.
So in summary congratulations on getting an official nickname please make it your avatar it suits you well
A fawking tailgate made out of 3/16 what are you trying to hold in the tub your gigantic balls
My crappy build
moveaside is offline   Reply With Quote Quick reply to this message
Old 12-21-2008, 10:25 AM   #7 (permalink)
Member # 124133
the tail gate is made out of 16 ga steel
Old 12-31-2008, 02:55 PM   #8 (permalink)
Member # 124133
got to put in some more bars
Old 12-31-2008, 04:32 PM   #9 (permalink)
sammy virgin's Avatar
Member # 111490
Is it just me or is that front bar by the dash look ceanked?
87 sammy,toyota's with 4.88 rear elocker, front spool, yj's, 01 vitara 2.0l Toyota Tranny
sammy virgin is offline   Reply With Quote Quick reply to this message
Old 12-31-2008, 04:41 PM   #10 (permalink)
Member # 124133
no the cage was made 4 a shock car. i have to cut it up to fit. that u see is a pance of dom tudeing im going to fill it in
Old 01-02-2009, 11:33 AM   #11 (permalink)
Member # 100923
damb! I thought my keyboard and spelling skills were bad
zk16vl is offline   Reply With Quote Quick reply to this message
Old 01-02-2009, 12:47 PM   #12 (permalink)
Member # 89600
this is just scary!
fordori is offline   Reply With Quote Quick reply to this message
Old 01-02-2009, 06:27 PM   #13 (permalink)
onewhitezj's Avatar
Member # 45304
your going to fill in the entire thing? like 2" of fill?
Professional thread killer since 2005
onewhitezj is offline   Reply With Quote Quick reply to this message
Old 01-02-2009, 06:36 PM   #14 (permalink)
onewhitezj's Avatar
Member # 45304
I did my cage much the same way, it was originally a cage in something else, but trimmed and notched the tubing where I did not have any splices in it, only welded at the notches. Not sure if that would have been possible with your setup, but its what I would have or would be shooting for. Seems like you have an awfull lot of splices in there..
Mines not the best looking cage out there, but I have approx $50 into it.
Just some suggestions.
Old 01-04-2009, 06:26 PM   #15 (permalink)
Member # 124133
got to make a truss on it tomm
Old 01-04-2009, 06:40 PM   #16 (permalink)
Member # 119799
i have found a new inspiration on how i want to build my cage and body mounts
05 TJ Willy's Edition; locked, 35" stt's on beadlocks, tube fenders, half top, double tri rear soon
willy05tj is offline   Reply With Quote Quick reply to this message
Old 01-04-2009, 06:44 PM   #17 (permalink)
Member # 27862
I want to see this build through,keep working on it timmy.....
86 samurai-tubebed,1link rear,22RE,l52 trans/w56,stock case 118"WB,35"mtr's
O'neal is offline   Reply With Quote Quick reply to this message
Old 01-04-2009, 06:48 PM   #18 (permalink)
Member # 50557
Holy crap!! Get the rust off before you weld!
Sounds like bay, not ass.
Bass Man is offline   Reply With Quote Quick reply to this message
Old 01-04-2009, 06:54 PM   #19 (permalink)
moveaside's Avatar
Member # 11983
Timmy I need you to clean up at least the weld area surface better before you weld its going to have holes like it does now and really kill the penetration. Your going be running weight and power you will need to address this now.
What did you plan on the upppers as far as the bolt size they are going to have the be the perfect size seeing as how its a tight fit?
If your going to sleeve the cage at least consider a larger piece of tubing drilled and ready for rossette welds to strengthen this area its in your best interest
My crappy build
Old 01-04-2009, 07:11 PM   #20 (permalink)
Member # 29177
x2, you beat me to it
Blind Driver is offline   Reply With Quote Quick reply to this message
Old 01-04-2009, 07:28 PM   #21 (permalink)
superswamper_800's Avatar
Member # 107931
Great start, you just need to get rid of the rust where you plan to weld
Slickrock Mafia
Dodge Ram,318,NV4500,NP241,Rocks,H1s/49Iroks,dovetail,leafs out back,links up front
superswamper_800 is offline   Reply With Quote Quick reply to this message
Old 01-04-2009, 08:23 PM   #22 (permalink)
Member # 124133
im going to clean it all up.going to weld all of it good this week end
Old 01-04-2009, 08:39 PM   #23 (permalink)
Member # 96029
Thats alot of rust you need to scrap that frame or spend a shit load of time with a grinder
Sami
Old 01-05-2009, 12:02 AM   #24 (permalink)
Member # 42266
Timmy's Telethon...
88 Samurai: 39.5 Iroks, 5:29's 6.5:1, 16v 4spd
txzuk1988 is offline   Reply With Quote Quick reply to this message
Old 01-05-2009, 04:21 AM   #25 (permalink)
moveaside's Avatar
Member # 11983
Bullshit you did not tack those in place you ran beads. A good weld will be in farther than you can see and definitely farther than you now can scrape off with a wire brush or grinder. You have to prep the metal before not after.
Take a angle finder and check those uppers while your here. If its not close to 45 degrees then you will need to run a panhard or relocate them. I can't tell from the pic I would think a bronco frame is wider than a sammy though to help with that. Its usually pretty hard to get a 45 out of uppers inside the framerail like that you will need some decent length to achieve that. The triangulation is what will hold the ass end centered otherwise you'll have expensive problems later.
My crappy build
