tracker/kick 5 spd. shift detents&royal purple - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-10-2009, 11:11 AM   #1 (permalink)
Member # 126040
i decided to dump valvoline 75w90 synthetic in favor of royal purple since it flows better in sub zero weather and have come up with a side affect. the shifter now move a little too easily, that purple stuff must be awful slick. at temps below +30 the cold shift boot pulls it out of 2nd; 4th and reverse are affected too if it gets much colder. once heater warms shift boot problem is gone. this time of year i am in and out of truck all day so cab stays cold often (coyote hunter). is there a stiffer detent ball spring out there? i want to keep the royal purple diff juice.
raging squirrel is offline   Reply With Quote
Old 01-18-2009, 07:33 PM   #2 (permalink)
Member # 126040
no takers? surely someone in cold climate has experienced this.
Old 01-18-2009, 08:49 PM   #3 (permalink)
Member # 48911
I can only suggest to get an engine valve spring tester to see how much pressure it needs to compress. then find a good spring shop and tell them the diameter, height, and load you need.
also, perhaps a leather shift boot would be more flexible.
cajunsuzukispider is offline   Reply With Quote
Old 01-18-2009, 08:50 PM   #4 (permalink)
Member # 48911
I've found the Thompson Register to be very very helpful and they have them at most major libraries.
Old 01-19-2009, 04:55 AM   #5 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
I would take the current springs out, and just go to a regular hardware store first and see what they have.
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 01-19-2009, 07:15 AM   #6 (permalink)
Member # 126208
So why don't you just put in the correct transmission oil? Both the transmission and transfer case calls for the rating GL4. Gear oil would be too thick. I switched my Tracker trans and transfer case over to synthetic Amsoil GL4 and the diffs to synthetic GL5 because it was so sluggish in cold weather. It now drives like it was warm outside.
skitime is offline   Reply With Quote
Old 01-19-2009, 02:46 PM   #7 (permalink)
Member # 38563
the shift boots on my yota tends to be very rigid at freezing temps
my tcase doubler won't even stay engaged until the cab warms up
I'd probably have someone make a shift boot for you from a softer material or possibly slide the boot further down the shifter handle and attach it with a hose clamp
maybe that will keep the boot from putting strain on the shift lever
I wouldn't change fluids as you are sacrificing cold lubrication of the tranny for a shift boot, doesn't make sense to me
95' 4Runner with 5VZ engine WTB...winch bumper
84' M1031 CUCV 37's, 8kW gen
Pietro is offline   Reply With Quote
Old 01-22-2009, 08:17 PM   #8 (permalink)
Member # 126040
the royal purple used IS the correct type. it too "drives" like it was warm outside. the resistance has been reduced to the point of the shifter being easier to pull out of gear, thus the problem with a cold shift boot( not cold oil). i may have to just turn the boot upside down so the shaft sealing end is close to the pivot point. or try a leather boot as someone suggested so my sandwich crumbs don't collect in an inverted boot.
