Powersteering Issue - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-11-2009, 03:19 PM   #1 (permalink)
Member # 121379
Powersteering Issue
I have an auto Sidekick with 35" rubber still on IFS.
The issue is that the P/S is strugging to keep up when the tires are aired down mainly turning on rocks and the like, the steering wheel gets very heavy and gets to the point where you cant turn it.
Is the stock kick pump and box up to the job?
Is the pump on its way out?
What do you think?
Toecutta is offline   Reply With Quote
Old 01-11-2009, 05:13 PM   #2 (permalink)
tinbeater's Avatar
Member # 16547
What do you think?
I when though 2 stock pump in a month years ago when I tried to use them.
Did'nt work for me.
tinbeater is offline   Reply With Quote
Old 01-11-2009, 05:28 PM   #3 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
Might want to go to a T/C style pump
You can do it ultra cheap by use jeep 4cly pump (it's a stock t/c pump)
Use the spidertrax pump mount and pulley
Use the stock jeep hose (cut the end off that goes to the steering box from both the hoses) put the zuk end on the jeep hose and double flare the line after.
Use the zuk reservoir
Bleed lines and go wheeling
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.ruffstuffspecialties.com
www.zukeviltwin.com
www.polyperformance.com
www.DEEPWOODSEXTREME.com
www.trailtough.com
supazuk94 is offline   Reply With Quote
Old 01-11-2009, 05:59 PM   #4 (permalink)
Member # 121379
So does that make it a pump issue?
Old 01-11-2009, 08:13 PM   #5 (permalink)
Member # 6054
the pump isnt really up to the task I would recomend a tc pump swap. just dont cobble together a hose. Have one made at a hose shop its worth the 30-40 bucks. Try that out and if you need more you will have the good baseline parts to make a hydro assist setup work well
Ben
Ben Holloway is offline   Reply With Quote
Old 01-11-2009, 08:22 PM   #6 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
Ben
you are not "cobbleing" swaping ends on the metal line is no differant than what the shop will have to do.
the line is the same diameter so the ends can just slide on and put a new flare. Its just like doing brakes
-UZI 9mm
thanks to:
www.zukeviltwin.com
www.trailtough.com
Old 01-11-2009, 09:03 PM   #7 (permalink)
Member # 126040
i run a psc-1200x with my hydro assist and love it. an oil cooler is a good idea if the pump is working hard, no matter which pump you choose.
raging squirrel is offline   Reply With Quote
