Member # 102111
looking for some guidence.
So im selling my 2005 tundra due to "hard economic times" and i really would like to build an extreme daily driver sammi . I've spent some time looking on the web sites. pondering suspension kits and im not too sure how to make heads or tails of some of it. i want to swap to toyota axels. fuel injenjection is a must. 36" 37" tires. i would like to strech the wheel base out to 100" or so. Besically im looking for some input. on motor swap/ tcase gearing. suspension kits. ext. any and all input would be awesome.
Just wheel it. |
Member # 126040
extreme and daily driver really don't go hand in hand. believe me, i am there. you will have to live with some trade offs. first, go through the Faq's section. a good bit of answers will be in there. if you plan to swap in the bigger 1.6 motor as most folks do, then you might want to get a sidekick/tracker and swap the toy axles to that. the trail tough swap kit would be easiest, but expensive. if you like to fab stuff, you can save lots of dough. scour through the build threads here before you start to see what worked for others. i suggest the kick/tracker since you won't have get engine swap parts, do any wiring, or mess with the little details that plague any such endeavor. you can dive right into axle swap, gearing, and t-case mods. this will save time, effort, and cash. if you want to swap some other power plant in, the the samurai is a better place to start due to the divorced case. keep in mind that this case won't handle v-6 power and hard use though. if you intend to swap in a complete engine,trans./t-case combo from something else, then either will require about the same effort. the samurai weighs a little less.
"never catch snow flakes on your tongue until all the birds have flown south for the winter." |
Member # 48911
I used to do hard, gnarly trails all the time for years in a mostly stock sammy. I had 31" tires, lockers front and rear, a SPOA lift. let some air out the tires and point and go.
#4 (permalink) | |
Member # 102111
ya i know all about wiring plauges. i spawped a 4.3l tbi into my 84 toy. i did the wiring harness myself and had some problems. next time the plans in buying a standalone kit from painless wiring. I want to build off a samuri base. drop in a 1.6 or 2.0. im not sure what tranny/t-case to run. Toyota axles ext. but who makes the best swap kit? rock road looks promising trial-tough is very reputable. i would like to link it. if i dont who makes the best YJ kit?
Just wheel it. |
#5 (permalink) | |
Member # 126040
