what springs?
Im trying to decide on what to run for springs on my Blamurai (see sig. at bottom). I know i'm going 4-link but i'm torn between coils or airbags (can't afford coilovers). anyone have any experience w/ airbags off road? I know the scorpions run them with amazing results but was just curious to durability, and what not. Opinions suggestions?
06 Grand Cherokee as DD ------ 95 Ranger w/ many options--------- 19?? Samurai w/ toy power! |
There are a few airbags that own sammies on this board
but as to your question of application of them to a Sammie, I have personally never seen one. Coils are becoming very popular (i'm installing mine soon) and there a lot of guys with custom creations lurking around here. There are a "few" coil kits available on the aftermarket as well. There is a thread on the board right now of sammie on coilovers with toy axles. But to answer your question, I just haven't seen any around.
RIP MSG Art Lilley, you will never be forgotten... |
Member # 10
From what I've seen, airbags will cost as much or more than coilovers--unless you have a source for cheap used 'bags, or something. You can get coilover shocks for under $200, plus your springs.
Since you've already decided to go with a linked suspension, your options are limitless--1/4 or 1/2 elliptic leaf springs, transverse leaf springs, coil springs, coilover shocks, air bags......
Carl Whitmore |
Member # 12017
Since its actually a chevy with only a sammi body the chevy board might be a better source for suspension details when it comes to spring rates and such..
79 CJ7 EFI401>th400>Atlas II 4.3> 60/14, 38.5 SX's, H1 beadlocks |
#5 (permalink) | |
#6 (permalink) | |
Member # 8111
an easy $500.00 per corner
Your right I own the Fucking Place All Rock 4X Fab Products Made IN THE USA!!! Rock 4X Fabrication,Inc 1-847-672-9653 |
#7 (permalink) | |
The chevy frame is just longer and stronger. I plan on centering the body on the frame and mounting the motor very similarly to 350samurai's with the extended hood. 350samurai...where or what did your coils come from that would hold up the small block.
#8 (permalink) | |
Member # 10
2 coil springs: $43 each, $86 Spring stack spacer, $16. Total, $301 per shock.
Carl Whitmore |
#12 (permalink) |
Member # 9166
air bags
Ben's LJ80
http://www.ottindustries.com/Suzuki_LJ80.html shameless plug... OTT makes good stuff... buy Canadian, eh? |
#13 (permalink) | |
Member # 8111
the dam things in pc.s sold athe axles and running gear so Ill be taken a stab in the dark
#14 (permalink) |
Member # 8672
Bummer.........
Nothing on ebay Don't you hate it when you're getting a bj and just as you cum - she sneezes and it comes out her nose..... Quote: Originally Posted by ScottFJ40 V2.0 This country is so full of pussies, it smells like a tuna boat crashed into a codfishcake factory. |
