buy the my-side or do home brew - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2009, 05:38 PM   #1 (permalink)
Member # 135022
hey guys, my stock carb has never ran very well and has been acting up lately so u need to get a new carb set up. i have seen alot of bad talk about the webers so am staying away from them since i do alot of offroading.
i want to do the harley cv carb set up. i have looked on the internet for hours today and have not found any diy cv carb set ups that have worked.
if i can make my own set up and save money i will. does anyone know of a diy cv carb write up?
jefftrucker12 is offline   Reply With Quote
Old 07-22-2009, 06:55 PM   #2 (permalink)
jims4x4's Avatar
Member # 10876
you could always buy the mount and find a used cv carb....
88Sami
jims4x4 is offline   Reply With Quote
Old 07-22-2009, 07:40 PM   #3 (permalink)
rockslutscoutII's Avatar
Member # 9725
I went with the My Side 2 from http://www.zuksoffroad.net/samurai_engine.htm
You add about $70 for a cv carb on ebay . and you are set. I think its the best thing i have done to the zuk yet. It is a turn key set up. Im alot like u ,i would rather build my own. (twin sticks) but its well worth it. My, thought of evertyhing.
I took my first trip to the Con last weekend. Right of the bat i found the carb to be running rough. I pulled the air filter and saw that either the float was stuck or the pressure was to high. So i wacked the bowl a few times with a screw driver. nothing so i backed the screw out on the reg to lower the pressure and it fixed it. The coolest thing about the my side is that if i wasen't able to fix it i could of called MY he is real good with getting back to ya with help. The rest of the trip was like running fuel inj. Not even a sputter.
Sorry for the long reply
Sammi on Waggys in the works
rockslutscoutII is offline   Reply With Quote
Old 07-22-2009, 07:46 PM   #4 (permalink)
Member # 135022
has anyone ever herd of running holly carb on a samurai. i found a guy selling a 2 barrel holly off a sandrail with a turbo for 200.
i just never seen a holly on a samrai but thought a vw engine is roughtly the same size as a 1.3l
Old 07-23-2009, 04:09 AM   #5 (permalink)
Skandinavisk pirat
ShuDuck's Avatar
Member # 30288
here is a good thread http://bbs.zuwharrie.com/content/topic,81164.0.html
yes, stay away from webers Never had my gixxer(CV) carbs cut out, it gets a little rich in extreme angles but doesn't die. I would make my own setup for sure, but I'm broke and cheap
ShuDuck is offline   Reply With Quote
Old 07-23-2009, 06:58 AM   #6 (permalink)
Member # 94747
Those are junk and to big to boot. A motorcraft 2100 bolts in the same place as the holley and actually runs on angles. I believe the smallest CFM on the holley is 360 and it will flood out on a 30* incline.
jr4x is offline   Reply With Quote
Old 07-23-2009, 08:54 AM   #7 (permalink)
Member # 135022
so if i got the holley 2300 and put the smallest possible jet in it, it would still flood my engine or could i possibly makeit work?
Old 07-23-2009, 09:06 AM   #8 (permalink)
Member # 3500
myside
get the myside, i had a weber and it ran like shit, but i didn't want to spend a bunch of money, i finally sucked it up and bought the myside and a used cv carb from a harley shop, it work awesome and is super easy to tune. -DT
dangerous toy is offline   Reply With Quote
Old 07-23-2009, 09:11 AM   #9 (permalink)
Member # 135022
the only problem right now is that i cannot find any cv carbs. i have called a ton of places and no one has any.the ones on ebay are still pricey too
Old 07-23-2009, 09:26 AM   #10 (permalink)
Member # 3500
carbs
there were a few years of kawasaki vulcan that used that same carb (the standard cv not the screamin eagle) if you do a bit of research/cross referancing you should be able to find one at a motorcycle shop -i had to drive 3 hours to get mine and it cost me $100. good luck. -DT
Old 07-23-2009, 09:44 AM   #11 (permalink)
Member # 135022
i am going to get the holley 2300 and the pull through turbo set up. i just talked to my friend and he told me the problem with a small engine and big carb is that there is not enought air in the air to fuel ratio but when you put a turbo on then it increases the air going in the system which makes up for the extra fuel.
he said somting along those lines but it make sense to me. if a vw can run that big holly carb than why not my samurai.
Old 07-23-2009, 07:33 PM   #12 (permalink)
Member # 71711
Go to a biker bar an I bet you can
find a stock H/D carb.
88sammi Waggy 44,s 538,s 5to 1 tcase yj front spring,s toy p/up rear spring,s turned backward,s saginaw power steering 36" tsl,s full cage
zukidave is offline   Reply With Quote
Old 07-23-2009, 07:48 PM   #13 (permalink)
Member # 17632
The jet you use won't help the flooding at extreme angles. The jet only sets your air fuel ratio, it will not help the fact that the carb runs like shit at an angle. I have heard lots of good about the Motorcraft carbs from the Jeep guys, so I'd personally go with that sooner than a Holley.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 07-23-2009, 09:06 PM   #14 (permalink)
Member # 135022
i am gonna try out the 2300 and if it floods too bad then i will replace it. i read some jeep forums and people have had good luck with them
Old 07-24-2009, 10:46 PM   #15 (permalink)
Member # 135022
alright guys, i am ditching the holly carb its just too big. and i am going to do the cv carb with turbo.
i just ordered the my-side stage 1 and a kihen 40mm harley cv carb. do you think i should stay with the myside or try the turbo too, since i have it.
Old 07-25-2009, 11:13 AM   #16 (permalink)
purevil71's Avatar
Member # 9275
Send a message via Yahoo to purevil71
Damn, too bad i didn't see this post earlier, I have a carb off my old H-D sitting in my basement. My new Harley if F.I.
"Just when I think you've gone and said the stupidest thing ever, you keep on talking!"
___________________________________
'88.5 Sami buggy on 37's
'96 4-door Tracker on 35's
ZookiMelt FB Page:
[url]http://www.facebook.com/profile.php?id=100003375889081[/url]
purevil71 is offline   Reply With Quote
Old 07-25-2009, 11:39 AM   #17 (permalink)
Member # 135022
hahaha. yeah
Old 07-25-2009, 05:26 PM   #18 (permalink)
BOFF's Avatar
Member # 38890
I know you made the right choice. I'm currently running a Weber, and it has done well, except on extreme steep inclines. Other than that, it does everything I need it to do. If I had the money, I'd go with the Myside.
Everything I've heard, read, and personal experience on the phone about/with My, is a positive. He has excellent customer service, and stands by his products.
Keep us updated on your thoughts.
88 Tintop DD- Toy 4.38s, lockers, YJ springs, 4.16 Tcase, 33s, Sidekick ps, etc, etc..
BOFF is offline   Reply With Quote
Old 07-26-2009, 08:46 PM   #19 (permalink)
Member # 44811
Send a message via AIM to kabob
I used a gas carb. off a fork lift, which worked like a champ dont know what kind or brand I had just went to the forklift repair place and found one that bolted to the intake
Josh
I DONT KNOW WHAT THE HELL IM DOING !!!!!
kabob is offline   Reply With Quote
Old 07-28-2009, 05:14 PM   #20 (permalink)
Member # 135022
i just got my cv carb inthe mail today and the my-side kit should be shipped out on friday at the latest. hopefully if it gets sent thurs i will get in on friday since they are about 2 hours from my house.
