Subaru 1.8 into a zuki.....? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-18-2009, 09:09 PM   #1 (permalink)
Member # 87457
My dad and I came up with this idea a while back and thought it would be pretty cool if it will work.
Has anyone ever put an old Subaru 1.8 carbed boxer engine into a zuk? Figured maybe a guy could use the subaru 4 speed tranny with the t case and leave the zuk t case in the rig for like a doubler setup....just take the CV's off the tranny and use the rear output.
Sorry if its been covered but did a quick search and could only find people using subaru master cylinders and stuff....
2000 Yukon Denali hidden inside a 1997 Yukon body :D SAS, hp d44, 14ff, 5.13s, 38s.....
Gearhead 1990 is offline   Reply With Quote
Old 10-19-2009, 08:40 AM   #2 (permalink)
Member # 7753
Search more, was just posted recently of one done in Brazil I believe.
Slowzuki is offline   Reply With Quote
Old 10-19-2009, 08:45 AM   #3 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
Here's a 2.2
http://pirate4x4.com/forum/showthread.php?t=679722
Don't know why anyone would swap in a carb'd motor.
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 10-19-2009, 10:04 PM   #4 (permalink)
Member # 102591
The subie boxer engines are too wide to fit in between the stock frame rails. Obviously not an issue on BillJ's rig but you'd have a ridiculously high COG using a stock frame.
-Dex- is offline   Reply With Quote
Old 10-20-2009, 07:24 AM   #5 (permalink)
Member # 106586
only reason to use pancake motors is if you aren't puting them in between your front wheels and you don't have a lot of overhead clearance. That's why they use them in a lot of rear and mid mounted applications. Put the fuel tank up front and Mount the engine behind the driver seat... that would be interesting for baja racing, but rock crawling would be bad.... you'd be on your back most of the time.
You can only smell fear if the fearfull have loose bowels.
Baratacus is offline   Reply With Quote
