Finally got a Samurai!! and some ???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-28-2009, 10:47 AM   #1 (permalink)
Member # 84343
Ive been looking for a new ride for a while. Im a former Jeep guy. I wanted something small, simple and cheap. I decided to get a samurai.
Specs: 1987- Toyota axles with a locker in the front and welded rear 4.10s. YJ springs all around. 6.5 t-case gears. Exocage. 36'' tsl's. Beat to death!
I need to know what TRE's these are because they in bad shape!!
It also has some type of power steering. What is it off of? Is a kit?
How do I ID the axles to know what year and 4 cyl or V6? I would like to re-gear this winter. I very pleased with it so far. Cant wait to take it out. Thanks in advance.
:flipoff2:
MULISHA JP is offline   Reply With Quote
Old 10-28-2009, 12:45 PM   #2 (permalink)
Member # 140741
Looks good i hope you enjoy it. Good luck!
saleen9973 is offline   Reply With Quote
Old 10-28-2009, 01:33 PM   #3 (permalink)
Member # 62837
The TRE's are prolly FJ80. Lots of kits used those: http://www.marlincrawler.com/steerin...teer-kit-hilux
Steering box and pump are out of a tracker/sidekick. Pretty weak setup. A PSC pump would definitly help it, but most switch to Toyota IFS pickup steering gear. Takes a bit of fabrication to get that going though.
I'd guess the axles are 4cyl. You need to look at the differential to tell. This will help. It has to do with the fins on the side of the diff. http://home.4x4wire.com/erik/diffs/
Looks like a fun rig. I also have the 4.10's, 6.5, and 36's. I would like a little more motor in high range. 1.6 Fuel injected might be a good upgrade.
88 Samurai, 104WB, Locked Up Yotas, 6.5's, 36's.
Chop and stretch: [URL="http://www.pirate4x4.com/forum/showthread.php?t=643403"]http://www.pirate4x4.com/forum/showthread.php?t=643403[/URL]
[QUOTE]I blew through two D60's ring and pinions, and three sets of superior shafts. I run 42" tsl's, and finally stepped up to a Cryo'd D30..... I will never look back[/QUOTE]
dabomb5756 is offline   Reply With Quote
Old 10-28-2009, 04:37 PM   #4 (permalink)
Member # 16608
Cut that gay ass stinger off the front and wheel the shit out of it the way it is...
Originally Posted by MULISHA JP View Post
Thanks in advance.
No problem, your welcome...
'88 Zuk
TatorZuk is offline   Reply With Quote
Old 10-28-2009, 06:17 PM   #5 (permalink)
Member # 84343
Thanks for the info guys. Yes I'm going to re do some of the tube work. I definatly love it so far. Every bit a capable as my heep was and cost me about as much as my front D60 did! Anymore things to look for or general advice on suzukis would be great. Thanks again
:flipoff2:
Old 10-28-2009, 06:29 PM   #6 (permalink)
Member # 125447
hell yeah i like it. drive it, break it, fix it, repeat.
wheelingyota is offline   Reply With Quote
Old 10-29-2009, 09:04 PM   #7 (permalink)
Marshall-88Zuk's Avatar
Member # 66388
That Track/Kick power steering will work good, not real strong but on 36s should alright. It does get hot as hell though so if you keep it put in a cooler.
Those FJ-80 tie-rod ends might be fine, they come raw steel and allot of guys don't bother to paint them. If that is just surface rust I wouldn't worry about it.
That rig should bring you allot of fun.
My junk:[url]http://www.pirate4x4.com/forum/showthread.php?t=747299[/url]
Marshall-88Zuk is offline   Reply With Quote
Old 10-29-2009, 09:13 PM   #8 (permalink)
Member # 84343
I was going to throw in a cooler and mabey a surplus center hydro assist set up. The boots on the TREs are dry rotted. I'll replace those but keep them for spares. I'm going to take it out sat. Or sun. Ill post up some pics. Thanks for the info
:flipoff2:
