high pinion diff. rear - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-27-2002, 11:44 AM   #1 (permalink)
Member # 4237
Will a Toyota high pinion electric locking diff hold up under the rear of a samurai. I run the 1600 16v and 6.1 t-case and plan on going to Toyota axles. The high pinion would help my driveline angles, but I have heard you should not run these under the rear. Thanks for your info.
87 samurai, spring over, shackle reverse, yj springs, rear missing links, RS 9000's, 5.13's, 6.1 t-case, locked front and rear, 33" km's, 1600 16 valve, cross over steering, and custom bumpers.
samuraiweasel is offline   Reply With Quote
Old 09-28-2002, 10:59 AM   #2 (permalink)
Pappa Smurf's Avatar
Member # 12401
Send a message via AIM to Pappa Smurf
why do you hAVE ONE
Pappa Smurf is offline   Reply With Quote
Old 09-29-2002, 08:08 PM   #3 (permalink)
Member # 4279
seems to me it still would be way toughfer than sammy axels .........you can break anything .........
bobaki is offline   Reply With Quote
Old 09-29-2002, 08:40 PM   #4 (permalink)
Member # 977
I'm pretty sure OILBURNER on this board has had one in the rear of his rig for a while.
eXtreme web-wheeler!
scwafish is offline   Reply With Quote
Old 09-29-2002, 09:09 PM   #5 (permalink)
Member # 10
I'd say yep, it'll hold up most likely. I ran one in both front and rear Toyota axles underneath a CJ2A for several years, and never broke it. (for reference, I was running the stock 4.10's)
Carl Whitmore
I Lean is offline   Reply With Quote
Old 09-30-2002, 11:54 PM   #6 (permalink)
Member # 7606
I've seen that setup on some pretty thrasher Toy pickups and they seem to have held up fine.
That's the FJ80 stuff? I'm pretty sure a couple of UROC guys are running them.
Rocky Road is offline   Reply With Quote
Old 10-01-2002, 07:11 AM   #7 (permalink)
Member # 10
Yeah, that's the FJ-80 front third member. They do hold up really well, but a high pinion diff is weaker when run in a rear axle.
Carl Whitmore
Old 10-02-2002, 06:15 AM   #8 (permalink)
Member # 5829
My hi-diff in the rear hasn't given me any problems.
If you play in the mud/water, I dunno if I would opt for the elect. locker - go spool instead.
0ILBURNER is offline   Reply With Quote
