4 link help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-06-2010, 12:32 AM   #1 (permalink)
Member # 93277
4 link help
Ok I cant really figure out how to get the 4 link calculator diagram on here but I can post the #'s. This is my first 4 link but I think the numbers are ok. But I would like some advice. what do you guys think.
Wheelbase 95.0 in
Tire Diameter 37.00 in
Tire Rolling Radius 19.75 in
Vehicle CG Height 40.00 in
Vehicle Mass 3,500 lb
Front Unsprung Mass 650 lb
Rear Unsprung Mass 500 lb
Upper Links x y z
Frame End 33.00 12.00 27.50 in
Axle End 0.00 3.00 25.00 in
Lower Links x y z
Frame End 40.00 3.00 23.00 in
Axle End 3.00 21.00 16.00 in
Static Anti-Squat 82 % Travel Anti-Squat: 82%
Roll Center Height 24 in Travel Roll Center: 24.17
Roll Axis Angle 0 degrees (Roll Understeer) Travel Roll Axis: 0.00°
Instant Center X-Axis 84 in Pinion Change: 0.00°
Instant Center Z-Axis 31 in Travel Amount: 0.00
Travel Increment: 1.00
I think i figured out how to post the diagrams.
lankster29 is offline   Reply With Quote
Old 01-06-2010, 11:09 AM   #2 (permalink)
Member # 67110
Wheelbase 95.0 in
I assume your tires are 37"s? Measure and see what they really are. Rolling radius is height from the ground to center of the hub, if you want to calculate at trail pressure, this is where to compensate. I am guessing 19.75" is a typo. I would guess those numbers to be about 36.25" and 17" instead
To get the calculator image, take a screen shot (alt + print screen on PC's if I remember) and post the image. That will make it a lot easier to see whats going on.
D Boz is offline   Reply With Quote
Old 01-06-2010, 05:15 PM   #3 (permalink)
Member # 106272
Dude, well done! now freakin get it done!!!!
my name is mud is offline   Reply With Quote
Old 01-13-2010, 06:50 AM   #4 (permalink)
I like .XLS
Greg72's Avatar
Member # 9393
Where did you get that version of the 4Link Calculator?
It looks a little bit newer than the one the Triaged has links to in his .sig
-G
Greg72 is offline   Reply With Quote
Old 04-05-2010, 08:46 AM   #5 (permalink)
Mykul's Avatar
Member # 157054
From what I have been reading those are some good numbers!! Nice work
Mykul is offline   Reply With Quote
