Volkswagen 1.6L Turbo Diesel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-09-2010, 10:24 PM   #1 (permalink)
Member # 81152
Few crappy cell phone pics of my recently started Volkswagen Turbo diesel swap into a samurai.
Freshly painted donor motor. 1.6l turbo diesel, eco version.
Freshly painted and rebuilt samurai transmission w/ petroworks heavy duty clutch installed:
Motor and Transmission Bolted together using Acme Adapters kit, heavy duty stuff, and no the jack+plastic lawn chair are not being used to support weight, they were there to assit me aligning the shaft on the transmission so that it would slide on correctly, the motor is bolted to the wooden crate using the motor mount:
Pic of the timing hole in the bell housing showing the new timing mark on the flywheel that came with the acme kit:
Close up showing how beefy the adapter plate is:
Image showing the new transmission position, which will lean slightly to the passenger side of the vehicle once mounted in:
And finally, a pic of something i need help with, identify the wire # 4 on the samurai ignition switch:
What is wire # 4 for!?!?!? its labled "AM" on the black plastic from which it protrudes...
#1. Solid Black w/ Yellow Stripe, labeled "ST" (starter?)
#2. Solid White w/ Black Stripe, labeled "ACC"
#3. Solid Black w/ White Stripe, labeled "IG" (Ignition?)
#4. Solid White, Labeled "AM"
I need help trying to figure out what goes to what so i can wire up the diesel motor....
grhawn is offline   Reply With Quote Quick reply to this message
Old 02-09-2010, 10:40 PM   #2 (permalink)
Member # 138552
it might be a ground, but i dont know, i hate electical.
as for a diesel in a samurai, i want to do it some day. sounds sick. i thought about puttin a diesel in my yota for a little while but i think a sammi would be a better application,
81 toyota 4x4 is offline   Reply With Quote Quick reply to this message
Old 02-09-2010, 10:40 PM   #3 (permalink)
Member # 81152
So far on the samurai i have
31" LTB
SPOA
SKY OTT steering
TT Bonz-eye Springs front and rear
Spidertrax ubolt kit
SKY lower shock mounts
TT HD Bone shackles
Poly U Bushings for springs
High clearance Transmission Mount
Rocky road (...) HD long arm for t-case
Davesport front cage
Fully herculined interior
Rustoleum bed liner sprayed on under belly + engine bay - i REALLY like the way it looks and so far its been pretty tough stuff, highly recommended for its price point...
cant think of anything else that ive done....
Future mods include R&P + Tcase gears along with full rebuild of t-case and axles
TT Chromoly axles front and rear
Rear ARB locker, open front
Old 02-09-2010, 10:43 PM   #4 (permalink)
Member # 81152
I highly recommend Acme Adapters if your going with a samurai or toyota application. my next project will likely be an old toyota pick up (round headlights) with a 1.6l TD. Ill post pics of the sammy when i get a chance.
Old 02-10-2010, 05:07 PM   #5 (permalink)
Member # 72478
why will the tranny lean?
ralphdogg is offline   Reply With Quote Quick reply to this message
Old 02-10-2010, 08:47 PM   #6 (permalink)
Member # 81152
because the original samurai motor sits "vertically" where as the volkswagen motor's "lean" they are not straight up and down, they sit at an angle in the engine bay.
Old 02-10-2010, 09:32 PM   #7 (permalink)
tdavis's Avatar
Member # 908
White/Yellow is the +12v feed from the battery. Or since it's probably faded, it's just +12v.
I take my zuk out for walks.
tdavis is offline   Reply With Quote Quick reply to this message
Old 02-10-2010, 10:45 PM   #8 (permalink)
Member # 152273
How easy is the wiring for the engine management?
bulrid8 is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 09:17 AM   #9 (permalink)
Member # 48335
an IDI vw diesel will run perfectly with ONE wire to the injection pump. Aside from that, hook up the alt, starter, gauges, and youre pretty much done. Some of the "complicated" turbo diesels require TWO switched power wires run to the IP, one for the fuel cutoff solenoid, and one for a timing advance thing or some such. In any case, wiring is dead simple.
The vw TDIs, on the other hand, are a whole 'nuther ballgame.
phil_j is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 09:21 AM   #10 (permalink)
Member # 48335
Yeah, acme builds a great kit. Are you using their engine mounts as well? I know the vw motors are leaned over pretty good in the stock application, but I sure don't remember mine being leaned that far over in my samurai using their engine mounts. They may have some lean to them, but I would have bet they were much closer to vertical. I've since made my own mounts, and the engine sits dead upright now.
Old 02-11-2010, 08:53 PM   #11 (permalink)
Member # 81152
I should have been more descriptive when i posted that picture, the transmission only leans slightly to the right once mounted into the vehicle. the picture is exaggerated.
I am using the Acme motor mounts, i also purchased a new radiator and radiator "kit" from them as well
As stated above the wire is dead simple and soon as i am finished wiring it up ill post pics
i wanted to reuse the samurai ignition switch, i ended up getting rid of the ENTIRE samurai wiring harness so i am starting from scratch
Old 02-12-2010, 03:17 AM   #12 (permalink)
Member # 30288
the stock engine lean quite a bit as well, not sure why the mounts in the ACME kit are so the tranny leans a little..when I made mounts I kept the tranny at stock angle. Is it to clear the hood? The engine does not care what angle it sits at anyway
Have you stripped the stock wiring? if not you can just plug the diesel into the +12v plug that goes to the coil. Engine looks good
ShuDuck is offline   Reply With Quote Quick reply to this message
Old 02-13-2010, 01:43 PM   #13 (permalink)
Member # 81152
i did strip every last wire out of the samurai. i will not be using the gauge cluster. i will be using a tiny tach for the tachometer (http://www.tinytach.com/tinytach/diesel.php) and a GPS for the speedo and navigation purposes. the tiny tach may not (?) be as accurate as a conventional tach, but for my purposes its fine.
The headlights and turnsignals will be on they're own seperate circut and im hoping to tap my ignition switch for everything else.
Old 02-14-2010, 08:08 AM   #14 (permalink)
azrocktrash's Avatar
Member # 25980
looking good rhawn,can't wait to see it on what's left of the GAP
86 tintop 1.3 w/t MS2 header 2in exhaust 462r/p w/t open diffs 6.5 tcase 33 km2s.
azrocktrash is offline   Reply With Quote Quick reply to this message
Old 02-14-2010, 01:49 PM   #15 (permalink)
Member # 81152
What do you mean "whats left of the gap"?
i havent been up there since the groups last run....
Got the motor mounted in today - realized the Rock 4x high clearance mount wont work without modification because of the new lean.....
trying to figure out a work around
Old 02-14-2010, 04:43 PM   #16 (permalink)
Member # 120505
The engine only leans becasue of teh way the adapter plate HAS to be..
Why doesn`t anyone on Pirate do a 1.9TD?
So much more ponies...
That eco diesel pump , you ll want to get yourself an LDA ASAP. you ll have very little power if you have a turbo.
Once you get an LDA and get yourself a EGT gage and turn the fuel up.
You ll end up breakig the sami tranny...
Until then, have fun with it... BTW when you do exhause 2.5" all the way back, no muffler needed. It runs relatively quite without one...
95 sidekick, custom longarms, 16" coilovers, VW 1.9TD , Toyota axles tranny and dual cases.
slim_badboy is offline   Reply With Quote Quick reply to this message
Old 02-14-2010, 07:25 PM   #17 (permalink)
Member # 25980
give me a call when you get to that point with the mount,maybe i can come over and we can toss around some ideas.
and read this and catch up.we need all the help we can get.
/forum/land-use-issues/862408-coronado-national-forest-under-attack-united-states-forest-service.html
Old 02-14-2010, 10:11 PM   #18 (permalink)
Member # 81152
what the freaking hell is this....
that pisses me off soo much....
The monkey wrench gang is the only thing that comes to mind...
Old 02-15-2010, 09:54 AM   #19 (permalink)
Member # 81152
LDA isnt ringing a bell for me... could be brain fart...
I probably wont put any time or effort into "tweaking" the power output of the motor so much as dumping money into making it reliable (timing belt, water pump, rollers etc etc).
with stock gearing i heard this combination needs atleast 31" tires. i will be putting 4.16 gears along with r&p, so power wont be an issue with the torque of the motor being at the low end...
I have a 1.9 ready to swap into a samurai... but first i have to wreck the 99 jetta that its in so i can use the motor...
Old 02-23-2010, 06:46 PM   #20 (permalink)
Member # 25980
how's the build going rhawn?
Old 02-27-2010, 04:37 PM   #21 (permalink)
Member # 81152
Here are some updates:
Old 02-27-2010, 04:37 PM   #22 (permalink)
Member # 81152
Old 02-28-2010, 04:11 AM   #23 (permalink)
Member # 129329
Nice and clean, I like it! I'm finishing up my body swap now and things, wiring wise, are much neater and clean. No where near like yours though.
1990 K5 - Tons and more
1988 Sammi - 16v, Yotas, 36's on H1's
Copasetic is offline   Reply With Quote Quick reply to this message
Old 02-28-2010, 10:58 AM   #24 (permalink)
Member # 81152
Thanks, the goal from the beginning was to keep it simple and clean. the headers are painted with the VHT high temp flame proof header paint, not sure why i grabbed orange.... but whatever. i got a deal on convoluted tubing so im going to keep everything wrapped up in that stuff.
Old 03-01-2010, 04:00 AM   #25 (permalink)
Member # 30288
Why Isn't the perches welded?
