Member # 113217
(zuk newb) swift motor overheating
Im a toyota kid
![]() ok so i bought i nice little sami a while ago its a tin top in decent shap on 28" tires with a reverse shackle. not bad. im just going to spring it over and put 31s on it. (daily driver) i was told that it has a swift motor but i dont know how to tell the difference. i know it burns oil but im going to fix that when school is out. after about 30 min of 50-65 mph driving my sami overheats... i watch the temp carefully and pull over when it starts to cross the line. do i have a problem? or is the constant 3500 rpm whats killing it? i feel like it still shouldnt get this hot but what do i know? first off i checked the coolant/water and it was almost all coolant. corrected that but there is still a problem... the thermo looks new. could it be a samurai thermo and not a swift? i know the part numbers are different. is there a way to know? water pump problem? with some good luck im getting some cheap 5.12s so i wont have to run it so hard.. common problem?
"i know this defies the laws of gravity, but as you can see i never studied law" (Buggs Bunny) Last edited by ec2469; 02-28-2010 at 11:04 PM. |
Member # 113217
any help is appreciated dont hate me because toyotas are better! :P
o wait i love my sami
"i know this defies the laws of gravity, but as you can see i never studied law" (Buggs Bunny) Last edited by ec2469; 03-01-2010 at 06:19 PM. |
Member # 16764
is it boiling over? or just showing hot on the temp guage? what do you have for a fan? Is there a winch or bumper blocking or partally blocking the radiator. What type of carb do you have. Is the timing corect?
i live in a world of stupid people and smart phones |
Member # 100095
I had the same problem and I ended up needing a new radiator it was all plugged up. I had the same symptoms as u i bet that is what it is
a stock sammy can wheel better than any other stock 4x4 |
#5 (permalink) | |
Member # 113217
its the mechanical fan style. clutch or w/e stock bumper but i did run with my hood popped (still latched) and it was significantly better it has a webber carb timing is correct
"i know this defies the laws of gravity, but as you can see i never studied law" (Buggs Bunny) |
Member # 113217
i forgot to mention that sometimes it will heat up on the gauge real fast and then go down. im guessing thats a thermo problem.
i went to a parts store and i need to figure out what year the swift motor is. is there any way that you guys would be able to tell from a picture?
#7 (permalink) | |
True procrastionation is the art of putting a task off until it doesn't need to be done anymore. Last edited by zukibrothers; 03-01-2010 at 09:12 PM. |
Member # 113217
![]() ![]() ![]() ![]() hope some1 can help me identify the year just noticed the rust under my battery tray... i will work on that one of these days.
"i know this defies the laws of gravity, but as you can see i never studied law" (Buggs Bunny) Last edited by ec2469; 03-02-2010 at 01:07 AM. |
Skandinavisk pirat
Member # 30288
could as well be a 8v swift engine, is it 1324 or 1298cc ?
not that it matters, it would be just like a stock engine anyway. is there tapped new holes for another thermostat housing? intake looks like it is from a 8v swift Last edited by ShuDuck; 03-02-2010 at 07:52 AM. |
Member # 147964
Im just throwing this out there but cant you get some numbers off of the block and head That would be a way to find out. Go to a local parts store and check if the thermostat even changes year to year on the swift and sami. Then see if the thermostat is even different between the swift and sami. Suzuki used a ton of the same parts between vehicles.
#11 (permalink) | |
Member # 113217
how would i use the numbers to check?
"i know this defies the laws of gravity, but as you can see i never studied law" (Buggs Bunny) Last edited by ec2469; 03-02-2010 at 09:34 AM. |
#12 (permalink) |
Member # 131556
my work truck(96 ford 460) does what you are saying heats up quick then cools down quick when the water pump is on it's way out. fan probably isn't an issue because at a constant speed above 30 or so the air coming in is more than it can pull. Did you try flushing the rad out yet? see if it's clean, and drop in a thermostat when you do it, then you'll at least have a starting point.
2006 SV1000S with 6xxx miles carbon fiber slipon's new rear tire needs a front tire runs great $4700 OBO |
#13 (permalink) | |
Member # 113217
it was said above that it is believed to be a swift intake. should i be getting the correct thermo for the intake or the block or the head? pretty sure its all swift i dont think the guy i bought it from was all that savy. ANY best guesses on years?
#14 (permalink) |
Member # 147964
If you got the numbers you could check in a haynes manual or the local parts shop may have it when they search in a theyre computer for the year, make, model, then when they pick the engine it sometimes has the engine code beside it. Im not 100% sure but I think your correct about it being a swift because of that intake. I think this site has a suzuki faq page. Try that also it may be in there.
#16 (permalink) | |
Member # 113217
yeah i will see what i can come up with now. Thanks for the thought and assurance that it is a swift motor.
#18 (permalink) | |
Member # 113217
i really dont think its that because there isnt water in oil or vice versa and im not loosing coolant.
"i know this defies the laws of gravity, but as you can see i never studied law" (Buggs Bunny) Last edited by ec2469; 03-02-2010 at 08:12 PM. |
#19 (permalink) | |
True procrastionation is the art of putting a task off until it doesn't need to be done anymore. |
#20 (permalink) |
Member # 147964
I wouldnt mess with that head gasket unless its bad. I take it when you said it goes through it fast you meant oil not antifreeze. If its oil. You probably just need to rebuild the top end. But forget that for now. Try the thermostat and go from there. Its probably just staying shut.
#22 (permalink) |
Member # 149482
So....I'm sort of a zuk newbie too, but I am very experienced at "'92 engine in a '95 truck with a '89 intake and '91 whatever"
the answer is to go to the parts store and get a couple of thermostats. they're only a couple bucks each so get 1 for a sammy, and if there were different part numbers for different swifts- get them too. KEEP YOUR RECIEPT. when you take your thermostat out it will probably be obvious which one it is, so return the rest. Done. also if they all look about the same....maybe they are, sammies usually arent very picky... just my .02 good luck |
#23 (permalink) |
Member # 113217
i think you misunderstand. i think that my motor has the wrong thermo because the one that is on it is pretty new
