Lengthening drive shaft - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-17-2010, 12:07 PM   #1 (permalink)
Skandinavisk pirat
ShuDuck's Avatar
Member # 30288
Lengthening drive shaft how to
First, spacers are gay So this is an easy way of lengthening your drive shafts. You might get away with out a lathe if you don't drive high speeds. these where very close to perfect with just lining them up on the male part
Split a stock female end in two, just made a groove to follow with a 1mm disc angle grinder
40mm of splines is acceptable contact area
this is 30mm stretched
correct diameter tube with holes for plug welds (80mm long)
tacked and checked in the lathe
ShuDuck is offline   Reply With Quote
Old 03-17-2010, 12:10 PM   #2 (permalink)
Skandinavisk pirat
ShuDuck's Avatar
Member # 30288
Plug welded and checked again on the lathe
Stock and lengthened 30mm complete
both done, all they need is prep and paint
Old 03-17-2010, 04:32 PM   #3 (permalink)
Member # 67470
Nice.... Another good use for a lathe! If ya needed to drive fast, it probably wouldn't run too much to have them balanced.
Good work!
Mope is offline   Reply With Quote
Old 03-17-2010, 04:56 PM   #4 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
why not cut the tube portion and lengthen that like most other shops do?
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 03-17-2010, 05:41 PM   #5 (permalink)
SMASHurai
toykilla5150's Avatar
Member # 65463
Send a message via AIM to toykilla5150
You can use schedule 40 pipe as it avalable in the same size. Its just another way to get a job done at home cheap!
I LOVE IT
you cant fix stupid people
87 zuk- modded/wheeler/DD
86 zuk- tub/registered propane
88 zuk- firewall/last rig
87 zuk- invisable w/title
toykilla5150 is offline   Reply With Quote
Old 03-18-2010, 02:36 AM   #6 (permalink)
Skandinavisk pirat
ShuDuck's Avatar
Member # 30288
The tube portion is balanced as it is made of three parts which is hard to get straight(the little tacked on parts is weights to balance them). The female part is machined out of one part which makes it balanced. Lengthened the tube part it would need balancing . I have no vibes with these
Old 03-18-2010, 09:36 AM   #7 (permalink)
Member # 48911
I did a similar thing with mine, but I didn't use a tube over the two splined pieces. I just welded the two together and they held fine. but that's a good job there.
4.3v6,t18,dana18, ford/chevy driveshaft, chevy front in front, chevy front in rear
cajunsuzukispider is offline   Reply With Quote
Old 03-20-2010, 05:28 PM   #8 (permalink)
Member # 72294
Done them with sch. 80 pipe. No balance and no vibs. This is what Trail Tough does. After breaking one of there's . I cut it apart and we made our own.
86 S/T 6.4, 5:13 diffs,yota P/S Spooled & locked
86T/Top 6.5,5:13 Diffs,yota P/S, Spooled & locked
87S/T EXCO,6.5,5:13,Welded,Locked,yoda P/S BLAH,BLAH,BLAH,ETC,ETC.
MAD ZUKS-Modified & Aggressively Driven
SUZUKI SAMURAIS
1madzuk is offline   Reply With Quote
Old 05-14-2010, 03:36 PM   #9 (permalink)
Member # 89104
I have a few extra female yoke ends here, I will be making my extended drive shafts the same way.
Trail Tough sent 2 1" spacers for the front shaft, IMHO it's about an inch shorter working properly. After two trail runs setup as TT recommends the female end of the drive shaft became loose and started making a hell of a noise at 25mph or greater.
I am wanting to move the front axle forward one in with the extra perch hole and get rid of one spacer, so I will need to extend the shaft by 3 inches(with a 1" spacer to clear the crossmember) to make it work properly. I'm thinking this may be possible like you built yours, If notI will have to add two yokes together to make it work.
Thanks again,
--Sky
skyman6529 is offline   Reply With Quote
Old 05-14-2010, 07:03 PM   #10 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
good way to gain a few inches on the shaft..
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.ruffstuffspecialties.com
www.zukeviltwin.com
www.polyperformance.com
www.DEEPWOODSEXTREME.com
www.trailtough.com
supazuk94 is offline   Reply With Quote
Old 05-14-2010, 08:29 PM   #11 (permalink)
purevil71's Avatar
Member # 9275
Send a message via Yahoo to purevil71
Thats sig worthy right there....
"Just when I think you've gone and said the stupidest thing ever, you keep on talking!"
___________________________________
'88.5 Sami buggy on 37's
'96 4-door Tracker on 35's
ZookiMelt FB Page:
[url]http://www.facebook.com/profile.php?id=100003375889081[/url]
purevil71 is offline   Reply With Quote
Old 05-15-2010, 08:41 PM   #12 (permalink)
Member # 48911
also, don't worry about getting rid of that balancing weight. a good driveshaft shop can get the shaft to within .001" of perfectly concentric and no weights will be necessary. the oem's only use weights to balance it cuz they make these driveshafts at high production volumes and don't spend the time getting it perfectly concentric. my driveshaft guy in lafayette, la does large truck driveshafts too and does great work. after centering everything perfectly before welding and checking it with a dial indicator to make sure it's within .001", he then heats and cools it strategically to make it perfect and it needs no balance weights.
a good shop should already be familiar with these steps.
