samurai t-case in geo tracker - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-04-2010, 07:57 PM   #1 (permalink)
Member # 129876
Question samurai t-case in geo tracker
would a suzuki samurai transfer case fit in a 2wd geo tracker usin a short drive shaft to connect the two it'll just be for off road use only thanks
cody1 is offline   Reply With Quote Quick reply to this message
Old 05-05-2010, 05:35 AM   #2 (permalink)
BRENTWADE's Avatar
Member # 52580
If you have a the fab experience you can do it and yes it could still be streetable.
2 Built Tube Buggy's V8's, ton's bla bla bla bla.
BRENTWADE is offline   Reply With Quote Quick reply to this message
Old 05-05-2010, 08:24 AM   #3 (permalink)
Member # 129876
me myself aint got much fab experience but my cousin does so hopefully he will be able to help me fab somethin up...i dont know much about geo's so i have one more question is 350 to much for a 2wd geo that needs a clutch?
Old 05-05-2010, 08:33 AM   #4 (permalink)
Member # 85796
No 350 is not too much if it runs good.
BIGJOEDUCKSLAYER is offline   Reply With Quote Quick reply to this message
Old 05-05-2010, 09:26 AM   #5 (permalink)
tanzuki's Avatar
Member # 15771
Send a message via ICQ to tanzuki Send a message via AIM to tanzuki Send a message via Yahoo to tanzuki
Or you could get a kicker 3 like from OTT and it would be a pretty simple fab. More $$$ though.
YO YO HA!!!
tanzuki is offline   Reply With Quote Quick reply to this message
Old 05-05-2010, 10:46 AM   #6 (permalink)
Member # 144164
then you have to worry about the front axle because If it is 2wd.. yada yada...
If it were me and were to do this. I would buy it and then buy a samurai and go from there. get the engine and pwr steering from it.
If you really wanted it in a tracker you would need to also get a sami front axle and another tracker 3rd member.
PuddleJumper55 is offline   Reply With Quote Quick reply to this message
Old 05-05-2010, 10:46 AM   #7 (permalink)
purevil71's Avatar
Member # 9275
Send a message via Yahoo to purevil71
Short answer is yes...
Long answer is, you will either need to do a body lift on the tracker, or cut the tunnel out to get it to fit (the way the samurai T-case mounts, it will hit the floor pans and won't mount properly). As well as fabbing up frame mounts for the case, and making an intermediate shaft to connect the tranny to the transfer case, which to me would be the easy part....lol
A tracker 4WD tranny/transfer would be a better option if you can find one, which should be too hard. That should just bolt right up.
EDIT: You will also need a front axle like Puddle Jumper said. A Sami axle with 2" wheel spacers on either side, and the correct gears (should be 5.13's, but don't quote me on that) will work and make for a nice SAS's rig.
"Just when I think you've gone and said the stupidest thing ever, you keep on talking!"
___________________________________
'88.5 Sami buggy on 37's
'96 4-door Tracker on 35's
ZookiMelt FB Page:
purevil71 is offline   Reply With Quote Quick reply to this message
Old 05-09-2010, 02:27 PM   #8 (permalink)
Member # 24142
i am trying to do the same thing so i will be following your post.. i was told there is a kit to put a sammy axle in a 4 wd tracker does anyone know who makes it .. and also good luck wit your build
WERE NOT HERE FO A LONG TIME JUST A GOOD ONE
UNFAMOUS is offline   Reply With Quote Quick reply to this message
Old 05-09-2010, 03:29 PM   #9 (permalink)
Member # 26115
Why do people still even consider sammy front axle swaps.
Trackers are far too heavy for them.
Do yourself a favor by not wasting money & time. Do toyota's or dana's.
SNAP CRACKLE POP , we did two SAS's with sammy fr. axle, didnt listen to people. STUPID mistake.
2002 Suzuki XL-7 37's-1Tons
Project XL-XL7
zuki4x4chick is offline   Reply With Quote Quick reply to this message
Old 05-10-2010, 05:04 AM   #10 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
glenn akja wildweasels old rig witha sami tcase
http://www.cs.umass.edu/~glenn/personal.html
-jay
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
supazuk94 is offline   Reply With Quote Quick reply to this message
