#26 (permalink) |
Member # 137759
Looks very nice!!
I would have just fish plated the chassi where you have the t-case mount... You never know with the samy chassis... ![]() Can you tell me the size of the bushings that you use for the motor mounts? I wanna do some like that on mine... Thanks! |
#28 (permalink) | ||
Limey
Member # 140900
Glad my build can help!Quote:
![]() A = 41mm B = 51mm C = 21mm D = 8mm E = 16mm F = 12mm G = 65mm Cheers Man, I’ll get some pics of the finished ones for you this weekend with a decent camera! Here's how I started them, gussets were then added that run along the edge of each plate to the axle.
#29 (permalink) |
Member # 137759
Thanks Scott!
I was thinking about the ones you used, from the spring, but then I thought they would be to small... But looking at your pictures they look perfect! Damn, I haven't seen my car for too long ...
#31 (permalink) |
Limey
Member # 140900
Starting to look more like an SJ again now
![]() T-case clearance ![]() Nice and Flat belly ![]() ![]() ![]() Gone for twin electric fans, these are controlled by a thermoswitch, one fan comes on at 88C and turns off again at 83C, the second comes on a 92C and turns off again at 87C, but I can manually overide this and switch them both on or off if wanted. ![]() ![]() ![]()
#33 (permalink) |
Limey
Member # 140900
Just a small update, not had a huge amount of time on it recently and I also moved to a new bigger workshop
![]() Got the Samurai rear axle fitted ![]() Modified the shifter to make fabbing the transmission tunnel top plate easier. ![]() Doubler shifter ![]() Started mocking up the top plate
#37 (permalink) |
Limey
Member # 140900
Cheers man
![]() A bit more progress, haven't had much time on it recently though. Bumpstops and shocks cut off the front ready for some hoops, I decided to relocate the bumpstops to under the chassis rails and a new Aluminium rocker cover. ![]() Rear bed and fenders cut out to raise the fenders, shock mounts, fuel tank and floor. ![]() Also pretty much got the trans tunnel finished after having a break from it. ![]()
#38 (permalink) |
Member # 89908
Hilarious, I didn't think there would be more than one Suzuki freak, named Scott, who own an 87 SJ410.
http://www.zukikrawlers.com/showthread.php?t=14532 |
#39 (permalink) | |
Limey
Member # 140900
who's the clone?
#43 (permalink) |
Limey
Member # 140900
Cheers Man!
Picked up the new axles for the SJ on Friday. Fully float rear conversion and Cromos up front. ![]() Also picked up this, could come in handy I think. ![]()
#45 (permalink) | |
Limey
Member # 140900
Here's a pic from when the old owner originally built the rear up.
#47 (permalink) | |
Limey
Member # 140900
#48 (permalink) |
Limey
Member # 140900
A small update
Rear bed & arches fully welded up ![]() Original Fuel filler hole filled in. ![]() Raised front shock towers built ![]() ![]() New front arches built. ![]() ![]() ![]() Trail fitted the front clip and fitted the modded inlet manifold with a HIF44 1 3/4" SU carb. ![]()
#49 (permalink) |
Limey
Member # 140900
The Sjs coming along now, hoping to have it all built up and on the road by the begining of next week.
![]() Sliders built ![]() rear bed finished ![]() ![]() relocated the front bumpstop mounts ![]() Transmission breathers plumbed in ![]() ![]() Also picked up a few new toys ![]() ![]()
