HELP!! tracker 3rd stud threads - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-02-2010, 09:50 PM   #1 (permalink)
Member # 153078
im putting tracker gears in my sami and am just using the complete rear tracker housing insted of a hybrid (bc im lazyyy...) anyhow, the studs in the housing for the 3rd member to bolt in, what is the stud size and thread pitch on them??? when i bought the axle it was just a housing and no hardware, i figured a regular metric nut would solve my problem, but that is not the case. any help is appriciated!!
87 sami tube chassis 2.2 Isuzu diesel, linked, toy axles, 38s
dsljnky is offline   Reply With Quote
Old 10-03-2010, 12:30 AM   #2 (permalink)
Member # 147705
I know this is not what you are asking about but I think it is worth your time...
I would shy away from the tracker axles. Mine had one when I bought it and I have always hated it. From your sig it appears that you are running 31’s as well, the pumpkin is just too large and scrapes on everything. I can't count how many times that damn thing has been the reason I couldn't get over a rock (it’s just embarrassing). As you mentioned above, you can’t get the same gear ratios as in a Samurai axle and you have to swap the side gears. To me that seems like a waste of time. I was driving through a field and destroyed the pinion bearing in my axle. I will not be fixing it as I do not like to spend money on junk. Instead I’m going to hot box my Toyota swap with 35’s.
darkness22-250 is offline   Reply With Quote
