i do i get to the wiper linkage? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-04-2010, 12:17 PM   #1 (permalink)
Member # 168586
The thread has broken off where the passenger side wiper hooks up. I've started to take off the dash but it looks like there is no way to get it out of there. I could pull it once i unhook it front the window motor, but i don't know how i'm going to get it back in.
anyone done this before?
1987 samurai tin top, weber carb, calmini header, 3 inch calmini lift, 4.16 gears.
critt3r is offline   Reply With Quote
Old 10-04-2010, 12:27 PM   #2 (permalink)
Member # 99158
unbolt the windshield, its attached to the frame
-Rob Tracey
[url]www.leded.com[/url][URL="www.toyotacrawlers.com"]
Northeast Toyota Crawlers[/URL]
[url]www.rok-freekz.com[/url]
88 Zuk - [url=http://www.pirate4x4.com/forum/showthread.php?t=765704]Build Thread..[/url]
[url=http://www.pirate4x4.com/forum/showthread.php?t=1004552]ZUK FOR SALE...[/url]
RTrac1 is offline   Reply With Quote
Old 10-04-2010, 12:38 PM   #3 (permalink)
Member # 168586
I just went back out there to see if i could make sense of what your saying. I've got a tin top so it could be different on my rig. i can't unbolt mine, it's got a seam holding it in. Even if i do pull it i don't think it's going to make a difference. Am i misunderstanding?
Old 10-05-2010, 08:42 PM   #4 (permalink)
Member # 48911
if you get the dash completely out of there, you should be able to access things from a large-ish hole. get some parts out of the boneyard and get to work! good luck.
4.3v6,t18,dana18, ford/chevy driveshaft, chevy front in front, chevy front in rear
cajunsuzukispider is offline   Reply With Quote
Old 10-05-2010, 09:42 PM   #5 (permalink)
Member # 113435
You've got to pull the dash all the way out, then pull the bracket that the three top screws (of the dash) go into.
72Fordzuki is offline   Reply With Quote
Old 10-05-2010, 10:50 PM   #6 (permalink)
Ditchbank Wheeler
zukesofhazzard's Avatar
Member # 44106
Where are you located? I have a parts rig that I wont be using any wiper parts out of.
Originally Posted by 71BRONCO71 View Post
A girls butthole is just like a 9 volt battery. You know its wrong to do, but eventually you put your tongue on it.
A bat flying at mach 10 will be just as confused as you are when it hits you.
zukesofhazzard is offline   Reply With Quote
