3 Link w/ Panhard Front Suspension - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-03-2010, 03:11 PM   #1 (permalink)
red90runner's Avatar
Member # 35527
So I've been researching linking the front of my samurai and have decided due to packaging issues that a 3 link w/ panhard is my best option. I've been messing around with the 3 link calculator but wanted to get some real world experienced opinions on how to build it. Mainly, what numbers to shoot for.
The rig is stretched 4" in the rear on XJ leafs and fox 2.0's. 37's. Toyota Axles. Toyota IFS steering box. Shooting for 98-100" wb and a 22-23" belly height.
I've searched a lot, but most of the good threads are in the Gen4x4 section and don't specifically pertain to samurais.
Any info you can give me before I start setting up the links would be beneficial. Pictures also would be extremely helpful. Thanks!
-Pat
red90runner is offline   Reply With Quote Quick reply to this message
Old 11-03-2010, 03:15 PM   #2 (permalink)
Member # 35527
/forum/general-4x4-discussion/546241-help-me-fix-my-broken-front-suspension-geometry.html
^ This was one of the better threads on 3 link/panhards I've read so far...
Old 11-03-2010, 04:23 PM   #3 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
4 link actually fits pretty easy
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 11-03-2010, 05:57 PM   #4 (permalink)
wolverine31's Avatar
Member # 85990
i did mine with the 3 link and panhard bar. 16" fox air shocks. also running yota axles.
wolverine31 is offline   Reply With Quote Quick reply to this message
Old 11-03-2010, 06:03 PM   #5 (permalink)
Member # 4565
Send a message via AIM to stoneyxj
This is my KentFab design.
The only thing i wish i would a done differently is the pan hard going from driver side frame to passenger side axle.
(yes these pics are OLD)
Stupis Sig
stoneyxj is offline   Reply With Quote Quick reply to this message
Old 11-04-2010, 01:25 PM   #6 (permalink)
Member # 35527
How? With the exhaust running down the driver side frame rail?
Any pictures with the upper mounted on top of the pumpkin and to the inside of the frame?
What material is everyone using for lowers/uppers. I'm leaning towards 1.75 0.25 wall. for the lowers. Opinions?
Old 11-04-2010, 02:30 PM   #7 (permalink)
Member # 67110
About what I was going to say. Not sure if he was referring to a triangulated 4 link, or parallel w/ panhard, but either way there isn't room without serious frame mods and/or moving the axle WAY forward
Not a great pic, I will try to find a better one, but that is exactly where my upper is
My lowers are 2" .250, and uppers are 1.5" .120
and the calculator
D Boz is offline   Reply With Quote Quick reply to this message
Old 11-04-2010, 02:33 PM   #8 (permalink)
Member # 14094
I used 2x.25 for lowers cause it was easy to get, and fit the bungs for my heims.
lowers are straight
uppers are triangulated
Size does matter.
Old 11-04-2010, 02:40 PM   #9 (permalink)
Member # 67110
lowers are straight
I assume you're running full hydro?
*edit replied before I looked at the last pic
Old 11-04-2010, 03:43 PM   #10 (permalink)
Member # 67110
a little bit better
Old 11-04-2010, 04:14 PM   #11 (permalink)
bakerthewrench's Avatar
Member # 149482
So.... wait. You didn't install you're panhard backwards did you??? Cause that would be like the most incredible bumpsteer ever
'95 Tracker- 16v
'8? Samurai pos spring over DD
bakerthewrench is offline   Reply With Quote Quick reply to this message
Old 11-04-2010, 04:40 PM   #12 (permalink)
Member # 82023
Im runnin a dual triangulated 4 link with an aerio 2.3 and all i had to do was cut the frame a little bit. I refuse to use a panhard setup. 4 links locating the axle left to right is way better than 1.
Ill take some pics this weekend after i get the front axle back under it.
Will
zukinut is offline   Reply With Quote Quick reply to this message
Old 11-04-2010, 05:13 PM   #13 (permalink)
Member # 67110
You make a pretty broad statement with no reasoning. Care to enlighten us?
FWIW I have nothing against triangulated links instead of a panhard, if I didn't have mechanical steering that's probably what I would do.
Also this car works OK with 'only one link locating left to right'
Old 11-05-2010, 12:32 AM   #14 (permalink)
Member # 82023
Its just a personal preference, i shoulda said that instead of how i worded it. My cruiser has a panhard bar and it works great.
And yes, that car works well. Better than anything ill ever build.
Old 11-05-2010, 02:07 PM   #15 (permalink)
Member # 106586
I love how HVY_CHEVY says stuff like.. "4 link actually fits pretty easy"
then you see his pictures and it's like.. "WTF am I even looking at? is that the front of a samurai"
Apparently The definition of "Easy" differs from person to person..
You can only smell fear if the fearfull have loose bowels.
Baratacus is offline   Reply With Quote Quick reply to this message
Old 11-05-2010, 02:32 PM   #16 (permalink)
Member # 14094
if you're looking to link the front end, chopping the frame off shouldn't seem like that daunting of a mod.
I did it using my trailer as a workbench with my rig on the lawn.
Size does matter.
Old 11-05-2010, 11:24 PM   #17 (permalink)
Member # 4565
you are joking right?
the reason i don't like it, is because my axle shifts a little to the right and the driveline kinda rubs on a bolt i have there.
Stupis Sig
Old 11-05-2010, 11:50 PM   #18 (permalink)
Member # 149482
haha! sorry, i guess you could say i was hesitantly joking. I'm no expert around here, and after seeing timmy's build i realize that not everyone learns about the basic geometry BEFORE they crack out the welder
Yours looks great in the pic btw, i'm trying to do a similar setup right now
'95 Tracker- 16v
Old 11-06-2010, 10:43 AM   #19 (permalink)
Member # 4565
lol its all good.
i understand the geometry of links. but i have never really understood how the pan hard works. all i know is it keeps the axle centered.. If it was a street rig i woulda researched it more.
PS i miss timmy! lol
Stupis Sig
Old 11-08-2010, 12:57 AM   #20 (permalink)
Member # 149482
Has anyone used one of the stock leaf spring mounts for the upper link? I'm having a hard time building my upper link mount because I need room for airbags on the lowers, so I was wondering how that would work. Pics would be awesome if possible!
Also I'm using a full width chevy dana 60 front not that it really matters
'95 Tracker- 16v
Old 11-08-2010, 05:07 AM   #21 (permalink)
jr4x's Avatar
Member # 94747
I wheel with a guy that built exactly what stoney did and it does have the worst bump steer of all time.
Originally Posted by stoneyxj View Post
lol its all good.
Its all good as long as its a trail only rig like you say. Since your panhard goes the oposite direction of the drag link when the suspension compresses it makes your tires steer to the right with out any movement from the steering wheel. So you hit the brakes it steers to right all by itself. Hit the gas and it goes left all by its self. Drive on a bumpy paved road going 20 mph or up and it looks like a drunk is driving.
jr4x is offline   Reply With Quote Quick reply to this message
Old 11-08-2010, 06:50 AM   #22 (permalink)
moveaside's Avatar
Member # 11983
Couple of things to get out of the way and figure out before welding.
How far can you either push the ifs steering box forward to clear the panhard rod.
Will the panhard clear steering linkage, coils, shocks, bracketry, driveline? Pvc is a cheap and easy way to mock all of that.
Yes its preferable to have the draglink and panhard be the same length and both to have good flat geometry so they do not fight against each other.
As far as performance the flatter or parallel to the same ground the more likely the front will "hook up" on the rocks and climb over stuff. It will also tend to not lift the back end up when you reverse. How do you achieve this? Look at the expamples of where's folks notched the frame. Noone does extra work for no reason. Its a PITA but its worth it. You lose ground clearance but its worth it when trying to climb especially with a swb vehicle. Vertical separation is less critical in the front it sees less torque due to weight transfer but keep it within reason.
My crappy build
moveaside is offline   Reply With Quote Quick reply to this message
Old 11-08-2010, 01:18 PM   #23 (permalink)
Member # 149482
Just to be clear, stoney did NOT in fact do that. Read a couple posts up, he already corrected me. He said it just rubs on a bolt because he didn't quite make the tolerances perfect.
Also- Hvy_Chevy: what are you using for a front driveshaft, a toyota cv front? Just wondering because I notice that with mine up that high the stock u joint won't make it.
'95 Tracker- 16v
Old 11-10-2010, 08:16 AM   #24 (permalink)
Member # 4565
i think that only applies if you have a drag link.. i have a ram up front.
The reason it bugs me is because the axle will shift over to the right a little and the driveline will rub on the lower control arm bolt..
Stupis Sig
Old 11-10-2010, 09:38 AM   #25 (permalink)
Member # 14094
Toyota IFS non-CV... good to 42*
Size does matter.
