Replacement body tub - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-12-2010, 04:12 PM   #1 (permalink)
Member # 163810
so i have been doing a little research and cant find what im looking for, does anyone know if they make a replacement tub? doesnt matter fiberglas metal whatever.
Oregon_Tin_Top is offline   Reply With Quote
Old 11-12-2010, 04:43 PM   #2 (permalink)
PENNPO's Avatar
Member # 155262
Aluminum Tubs
http://www.aqualu.com/aqualu_land_cr...uzukis_009.htm
PENNPO is offline   Reply With Quote
Old 11-12-2010, 04:47 PM   #3 (permalink)
Member # 163810
stupid question maybe but i looked at that do the lwb sammys and the swb sammys run the same frame..cause if so i just found my new tub
Old 11-12-2010, 06:43 PM   #4 (permalink)
GreyZuk's Avatar
Member # 81232
http://www.lowrangeoffroad.com/suzuk...base-body.html
GreyZuk is offline   Reply With Quote
Old 11-12-2010, 09:37 PM   #5 (permalink)
Member # 163810
thanks penn, thanks grey. do either of you know off the top of your head if i can run a short wheelbase sammy frame and long wb sammy body? im sure it will take some tooling but i would rather not have to stretch the frame...
Old 11-12-2010, 09:43 PM   #6 (permalink)
Member # 148314
yes ,more than likely you would want to stretch the frame. the lwb tub is about 13.5 longer between the wheel openings.
stretched 86 samurai , 1972 lj10
feather river rock crawlers
samicrawl is offline   Reply With Quote
Old 11-13-2010, 02:46 PM   #7 (permalink)
Member # 3895
Swb frame dimensions
http://www.suzukiinfo.com/sierra/sam...dimensions.jpg
Lwb frame dimensions
http://www.suzukiinfo.com/sierra/sam...ensionslwb.jpg
1987 LWB
ian_r is offline   Reply With Quote
