Hackjob sidedraft - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-30-2010, 08:27 PM   #1 (permalink)
bakerthewrench's Avatar
Member # 149482
Hackjob sidedraft
I needed to fix some fuel issues on my dd/pos samurai, and all the wires/hoses to the stock carb were hacked by the previous owner. My solution was this little round slide mikuni. 34mm is probably way too small for most people, but I'm trying to get a couple extra mpg while I'm at it. $100 brand new from the motorcycle shop through parts unlimited, and ultra simple. I'm still workin on jetting it in (it runs really rich as delivered) but I slapped it on and drove it to town fairly successfully today.
Yes. I know I need an air filter. Workin on it
'95 Tracker- 16v
'8? Samurai pos spring over DD
bakerthewrench is offline   Reply With Quote
Old 12-30-2010, 09:21 PM   #2 (permalink)
Member # 67470
What was your overall impression of it?
Mope is offline   Reply With Quote
Old 12-30-2010, 09:22 PM   #3 (permalink)
Crawford's Avatar
Member # 156125
ghetto fab thread nominee anyone?
Originally Posted by camo View Post
....we care
Tutum te robore reddam
Crawford is offline   Reply With Quote
Old 12-30-2010, 09:26 PM   #4 (permalink)
Member # 149482
It's too rich to really tell yet (smoked all the way to town) but I ordered some new jets and will update this once it's running clean. The flow pattern I made in the intake is absolutely horrendous, but hopefully it won't really matter much with such a small carb.
Otherwise, however, I'm already really impressed with the simplicity.
The biggest downside so far is until I securely mount an air intake, the carb shakes a lot and drips some fuel out of the overflow sometimes It's made for a dirtbike/snowmobile though, so I believe that will go away.
'95 Tracker- 16v
Old 12-30-2010, 09:28 PM   #5 (permalink)
Member # 149482
I don't mind
edit: the ghetto fab thread needs more pictures lately anyway
'95 Tracker- 16v
Old 12-31-2010, 09:55 AM   #6 (permalink)
Member # 89104
If you are not already use a jeep bypass filter to reduce your fuel pressure. if you are running that straight from the pump I bet you have too much fuel pressure, hence the rich condition.
They are made for gravity feed so the pressure needs to be 1.5- 2lbs max.
The jeep filter is from a Cherokee with a carbed inline-6. It has a main input and two outputs. You take the larger input and send it to the carb. The smaller outlet goes down hill to the return line. it keeps the pressure from building up.
So far for low pressure systems the jeep filter has been the most reliable to get a good pressure. Do not use a dial type pressure regulator, they are junk. I learned the hard way after trying one even though I knew better.
skyman6529 is offline   Reply With Quote
Old 12-31-2010, 10:41 AM   #7 (permalink)
Member # 114559
To much hackjob redneckism goin on here. Jeep filter is way to advanced for this set up... I see a hole cut in the hood and a gas tank from a honda trail 50 sitten on top of that carb.
if it isnt broken, fix it till it is
Wildfinger is offline   Reply With Quote
Old 12-31-2010, 06:20 PM   #8 (permalink)
Hvy_Chevy's Avatar
Member # 14094
Send a message via AIM to Hvy_Chevy
why a hackjob? cause he didn't CNC an adapter for the carb? bet all the other bike carbs started out as "hack" jobs.
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote
Old 12-31-2010, 07:12 PM   #9 (permalink)
Member # 67470
x2. I like the fact you're running what you've got, and making it work.
Old 12-31-2010, 07:29 PM   #10 (permalink)
sikmusicfreak8's Avatar
Member # 141259
total hack job! and i think im gonna try it on my beater sammi i have a 39mm flatslide dirt bike carb and a sammi with carb issues sittin in my yard.
sikmusicfreak8 is offline   Reply With Quote
Old 12-31-2010, 08:28 PM   #11 (permalink)
Power?
HumZukie's Avatar
Member # 96316
Send a message via AIM to HumZukie
The OSHA orange looks good.
88zukToysAussies6.5:1YJ34x10.5
Like everyone and there mother has!
HumZukie is offline   Reply With Quote
Old 12-31-2010, 10:16 PM   #12 (permalink)
Member # 149482
Thanks for the tip on the regulator, if I can't find a reliable mount for my trail 50 tank I may just try that. I should probably have looked up what the stock fuel pressure was, but since this carb is also sold as a snowmobile carb, I figured it could handle a couple psi (sleds run pumps because the tanks are mounted low). Better to be safe than sorry though
'95 Tracker- 16v
Old 12-31-2010, 10:41 PM   #13 (permalink)
Dodge Ram Newbie
DakAttack's Avatar
Member # 26814
I run 4 mikunis and I use a jeep bypass filter and still had to meter it down beyond that or over time the carbs would flood. I put a cheap in line gage and metered it down around 1 to 2 psi and stopped having the flooding issues.
Loren
Still Learning
2002 Dodge Ram 2500 5.9 diesel 4x4 6speed, 1987 Samurai Tintop (first complete rollover will inspire certain upgrades!)
DakAttack is offline   Reply With Quote
Old 01-01-2011, 08:40 PM   #14 (permalink)
Member # 149482
Today's update: I leaned out the low-speed circuit a little, and ended up a few sizes bigger on the mainjet. Overall, it carburetes excellent at this point. It is running smooth, and goes 65 on the road (very scary in this unit, the driveline is making all kinds of bad noises now- this is the first I've had it on the road).
It's still "fumey" though, and I will need to play with timing a little because it was never really set right, and I'm not sure if the advance is working.
'95 Tracker- 16v
Old 01-02-2011, 08:47 AM   #15 (permalink)
Member # 137066
try tying down your carb all that shaking around could be bouncing your float and raising your bowl level
SamyGuy is offline   Reply With Quote
Old 01-08-2011, 12:44 PM   #16 (permalink)
Member # 149482
So, still no regulator, but I haven't noticed any flooding since re-jetting. I am definitely bummed that it is only getting 10-15 mpg (how can a zuk suck that much fuel!?) but I'm stoked to finally be driving my sammy every day With this newest information, I would probably not recommend the basic round-slide again, I'll try a vacuum-slide (similar to the my-side conversion) next time.
'95 Tracker- 16v
Old 01-08-2011, 03:12 PM   #17 (permalink)
Member # 72478
either way it's awesome. try to avoid the minitrail gas tank and just go with a plastic DR 50 tank. keep it suzuki
ralphdogg is offline   Reply With Quote
