3 speed auto not shifting - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2011, 09:27 AM   #1 (permalink)
lenross1's Avatar
Member # 105385
Hey Guys,
I installed a 3 speed tracker/kick auto behind my 1.6 8 valve motor. I chose this tranny due to the lack of electrical connections needed. I have first and reverse but i will not shift into second or third. I don't think i can even manually shift it to 2nd.
I have NOT installed any of the wiring or the kick down cable. If the wires half to be installed where does each go?
I have searched and found nothin'
Thanks for the help in advance.
87 samurai 3sp auto/1.8 kick tcase/4:1 dana300, yota axles, 4 link rear, 39" krawlers.. reds
build thread:
97 FZJ80 supersets,chromoly rear axles,4.88s , 345 KM2s
lenross1 is offline   Reply With Quote Quick reply to this message
Old 05-30-2011, 10:25 AM   #2 (permalink)
Member # 168482
wow your fast you posted the same post on zk and your post are the first ones that come up under new posts. im shure betwwen the two youll get your answer. good luck.
16v w56 dual toys w/ 4.7s, 5.29 ARB Toys, Longs, hydro steer, linked f/r, 108 wb, 39.5 iroks
nickrocks is offline   Reply With Quote Quick reply to this message
Old 05-30-2011, 01:51 PM   #3 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
I don't have the kickdown or wires connected, and mine shifts.
Do you have the vacuum line connected?
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 08:42 PM   #4 (permalink)
Member # 68882
X2 on making sure you have the vacum line connected. i also have no wires or kickdown
hooliganZUK is offline   Reply With Quote Quick reply to this message
Old 06-01-2011, 07:49 AM   #5 (permalink)
lenross1's Avatar
Member # 105385
Vaccum line is connected. Does it matter which vacuum line to T off of. I picked a line that was pretty small in diameter.
build thread:
Old 06-01-2011, 07:54 AM   #6 (permalink)
lenross1's Avatar
Member # 105385
This is the vaccuum line i tapped into. Its the one that comes out of the top of intake near the thermostat.
build thread:
Old 06-01-2011, 07:56 AM   #7 (permalink)
lenross1's Avatar
Member # 105385
I was told it could be the vaccuum modulator ( what i am pointing at) or i could use more tranny fluid.
build thread:
Old 06-01-2011, 01:04 PM   #8 (permalink)
Member # 89104
Low fluid, or lack of fluid will definitely cause it not to shift properly. If you get that vac hose and everything you need hooked up and it still does not shift, pull the pan, and clean the screen and flush the fluid.
Over half the time a good service will cure allot of automatic transmission problems.
skyman6529 is offline   Reply With Quote Quick reply to this message
Old 06-01-2011, 06:40 PM   #9 (permalink)
Member # 128317
That's the vacuum modulator. Some have a screw in them you get at through the hole the vacuum line hooks up to. Changes the shift points. You should also hook up the wires, or the torque converter won't lock up. I use to have mine switched so I could leave it hooked and walk the rig down hill like a manual.
There were pic brake downs of the trans on Ebay. Bunch of stuff on Australian Holman site.
baldfatdad is offline   Reply With Quote Quick reply to this message
Old 06-01-2011, 06:46 PM   #10 (permalink)
lenross1's Avatar
Member # 105385
Thatone thing i didnt like coming down hill in the auto no compression braking. So you are saying i could hook up the lock up converter wire to a switch and it would be like having compression braking ?!
I am all for that!
Is it just a matter of hooking to a ground and 12 v source or do i need a freakin relay? I am terrible with wiring..
build thread:
