wiring offroad lights to stock switch - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-02-2011, 05:41 PM   #1 (permalink)
Member # 185199
ok got some 5 inch KC apollo lites, driving and long range, 55w, my thinking is put the driving lights to replace the stock lights and hook those up to my side marker wiring, that when i turn on the lights those will come on, then to wire the long range lites uo to hi beam, that way can have just driving lites on, or if more light needed have all 4 on at same time, see no reason it shouldn't work, the lights also have fuseable links in place
rich crook is offline   Reply With Quote
Old 07-03-2011, 10:40 AM   #2 (permalink)
Member # 125325
Send a message via AIM to Diesel Nut
Use a a relay on each set. This way you don't overload stock wiring, and the aftermarket lights are powered right from the battery. Its simple to do.
86 Samurai
16V, some tube, 42's, dual cases, yota axles, blah blah blah
Diesel Nut is offline   Reply With Quote
Old 07-03-2011, 10:46 AM   #3 (permalink)
Member # 48911
so you got a pair of lights that come on with the marker lights?
and one that comes on with high beams?
what about low beams?
seems you could hook 'em all to the headlight wires, that way you could have marker lights on without any headlights. could come in handy. you know, for when your girl makes you go tour the neighborhoods with all the christmas lights and everybody's hating on you cuz your headlights won't go out.......
4.3v6,t18,dana18, ford/chevy driveshaft, chevy front in front, chevy front in rear
cajunsuzukispider is offline   Reply With Quote
Old 07-04-2011, 07:34 AM   #4 (permalink)
Member # 9033
Originally Posted by cajunsuzukispider View Post
what about low beams?..
uhhhh.... marker lights...
My build: [url]http://www.pirate4x4.com/forum/suzuki/1022756-sidekick-tracker-pickup.html[/url]
MudKick is offline   Reply With Quote
