4.3 in samurai what tranny are you runing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-11-2011, 05:25 AM   #1 (permalink)
Member # 111372
i'm getting my motor today just don't know if i wanna run a sm420 or would the yota 5 speed hold up to the vortec 4.3?
zukion33s is offline   Reply With Quote Quick reply to this message
Old 08-11-2011, 06:04 AM   #2 (permalink)
Member # 83827
My brother inlaw runs a turbo350 / Toyota case! had to run 2" body lift though.
96 12v cummins,.... 5 ton rocks....big r2s .......blah blah blah...who cares its a damn mud truck!
cumminsontherocks is offline   Reply With Quote Quick reply to this message
Old 08-11-2011, 07:00 AM   #3 (permalink)
Member # 34281
Send a message via Yahoo to keller
The Sm420 is old, sloppy, loud, heavy, hard to shift and the gears are spread out WAY to far.
The only thing going for it is the LOW first gear range.
I would rather have a yota trans with a doubler. But the sm420 will almost match that gearing with out a doubler. So its a toss up.
Shop build
My buggy build
keller is offline   Reply With Quote Quick reply to this message
Old 08-11-2011, 07:40 AM   #4 (permalink)
purplezuki's Avatar
Member # 187305
Buddy of mine runs a 4.3 with a TURBO 350 ,reverse manual valvebody,big aliminum pan....it still has the zuki tub in it,with a heavily modified trans tunnel,I know because I redone the interior aluminum panels in it
It has a 4.3 ATLAS case, & chevy ton axles under it.
see my pics at www.scottspics.smugmug.com
purplezuki is offline   Reply With Quote Quick reply to this message
Old 08-11-2011, 07:45 AM   #5 (permalink)
Member # 48911
I didn't use the sm420 cuz it was heavier, wider, and longer than the ford t18. plus the ford tranny uses an adapter to the t-case which is only one inch long.
the sm420 adapter was longer, and I didn't want that length.
. I'm glad I did, cuz now my front and rear driveshafts should be about the same length.
4.3v6,t18,dana18, ford/chevy driveshaft, chevy front in front, chevy front in rear
cajunsuzukispider is offline   Reply With Quote Quick reply to this message
Old 08-11-2011, 09:42 AM   #6 (permalink)
Member # 37690
Send a message via Yahoo to blackrider
W56
4.3 vortec/tbi,yota axles/dual cases,40's,
stauns,oba,4 linked,coilovers,zook tub
[COLOR="blue"][SIZE="3"][FONT="Comic Sans MS"]NotQuiteRight Wheelers[/FONT][/SIZE][/COLOR]
blackrider is offline   Reply With Quote Quick reply to this message
