wire feeders, power source, diesel generator, ... - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Tools and Equipment
Old 03-30-2012, 11:28 AM   #1 (permalink)
Member # 119827
spring cleanup
- Cobramatic "push-pull" wire feeder
set up for welding aluminum
has shielding gas and gun water-cooling ports/connections
~20 foot gun included (however, i managed to loose the welding nozzle/tip )
didnt use it for some time (obviously collecting dust) so it needs to go
reduced to sorry; SOLD or best offer
- Two Lincoln LN25 "suitcase" wire feeders
one (grey case) is set up for fluxcore (includes a 2/3 full 33lbs roll of wire)
gun was acting up some last time i used it, so it may needs a new gun or trigger switch
the second one (black case) is set up for MIG
seems to have a problem with the main board.
however, the feed motor & shielding gas solenoid work.
i replaced the feeder with a Miller unit so i never really looked into repairing it
i`m including it "as is/ for parts" without a gun
i guess parts could be mixed to turn the fluxcore into a MIG
reduced to sorry; SOLD obo for the two (2)
- Miller CP-200 DC power source
industrial welder (200 amp @ 100% duty cycle)
3-phase 208/240/480
older unit but virtually bulletproof (and has a very sweet arc)
$ 300 obo
- large HD 30 KW Diesel generator
Military surplus
right now set up to produce 220V/ 3 phase/ 60 hertz ... can be set up for 208 to 480 V and also for 120V single phase if desired.
(one "build in" outside double-outlet of 110 V (IIRC 30A) is constantly powered regardless of actual setup of the generator)
powered by a 1800 RPM, 298 cid White/Hercules I-6 diesel (model D298ER)
very conservative rated at 30 KW (MIL spec)
build in 20 gallon diesel tank as well as twin starter batteries
has full instrumentation/dashboard with full array of fuses and line breakers.
completely weather enclosed and mounted on a HD steel skid.
weights approx. 2850 lbs (!) and is roughly 80"L x 55"H x 36"W
older unit (~8500 hours) but strong running and virtually bullet proof
this is the exact same unit , just a lot newer (and a lot more expensive ):
http://www.ebay.com/itm/30kW-MEP005A...ht_1296wt_1163
i used it to power the 3 phase MIG as well as my large vertical 3 phase mill (also for sale) ... was cheaper then having the power company run 3-phase into the shop
price reduced to $ 2500 or best offer
- pivoting welding arm
home made (made of DOM tubing & flat steel)
17 feet long
ball bearing beam roller "truck"
pivots on two 3/4" chrommoly rodends
great to suspend the wire feeder over your welding table/area
never ever trip over the leads on the ground again
(note; wire feeder and leads not included)
$ ?? ...make me an offer
located between Kingman and Flagstaff
... i may consider delivery for fuel money
pm me if interested
"Steels gonna be the death of me" ... Gangstergrass
RoosterBooster is offline   Reply With Quote
Old 04-09-2012, 11:15 AM   #2 (permalink)
Member # 119827
i "may" drive to the Reno/ Sacramento area sometimes this week
could deliver some of this stuff (or all of it)
PM me if your interested
Old 04-11-2012, 09:38 AM   #3 (permalink)
Member # 119827
last chance for possible free delivery anywhere along the way of northern AZ to Sacramento ...
make me an offer
Old 04-12-2012, 08:33 AM   #4 (permalink)
Member # 119827
reduced the price on the wire feeders
Old 04-19-2012, 07:42 AM   #5 (permalink)
Member # 119827
still available ....
Old 04-25-2012, 11:08 AM   #6 (permalink)
Member # 119827
ttt
Old 08-03-2012, 06:51 PM   #7 (permalink)
jamespadgett's Avatar
Member # 99417
still have this?
jamespadgett is offline   Reply With Quote
Old 08-06-2012, 03:26 PM   #8 (permalink)
Member # 119827
Originally Posted by jamespadgett View Post
still have this?
yes, everything is still available
(btw found the cobramatic welding nozzle ; she is complete now)
Old 09-13-2012, 07:54 PM   #9 (permalink)
Member # 228182
On the ln-25's
the gray one - does it have a contactor & gas solenoid or is it a dedicated F/C only model?
the black one - does it have an internal contactor?
Just asking because i think lincoln made a few different varieties of the ln-25.
Do you have any more pics of them?
Can/are you willing to ship the feeders?
welderboyjk is offline   Reply With Quote
Old 10-15-2012, 09:39 PM   #10 (permalink)
Member # 228182
So is this thread dead?
Old 10-21-2012, 03:41 PM   #11 (permalink)
Member # 99417
me thinks so.
Old 10-23-2012, 11:26 PM   #12 (permalink)
Member # 119827
sorry... i`m busy with my move and forgot to check this thread
the wire feeders are gone ... but the big diesel gen and the power source are still available
Old 11-03-2012, 03:22 PM   #13 (permalink)
Newbie
Member # 157605
PM sent on the generator
olanchamedic is offline   Reply With Quote
