Member # 30012
Onan 4000 generator, TX.
http://s795.photobucket.com/albums/y...ccess4tx/onan/
2007 model Microquiet generator, came out of a 2007 toyhauler. I purchased a portable generator to use at home too, so this is no longer needed. Starts and runs perfectly. Comes with everything needed to install in an RV, side output exhaust pipe, gas tank with quick disconnect that rides on top of generator, I usually set it outside when the generator is running though, remote start kit with hour meter, currently at 489 hours, and external 50 amp plug to plug your RV power supply cable into. Changed oil and installed new spark plug last month, I know everyone says this, but it's true. All necessary cables are included to hook to your battery for starting, ground cable for RV frame connection, and wiring for the remote start switch. It also has a start switch on the generator itself, if you don't want to use the remote start. Everything is ready to plug in and run, I did cut 5 small wires that go to the remote start, to ease taking it out of the RV, but they are all color coded and can be connected back with simple butt connectors. It will easily run my 15k AC unit, and microwave at the same time, no issue. Also have the original manuals that came with it new. $2000 FIRM, no trades. If you want to arrange shipping, I'll be happy to drop it off in the Austin area. The shipper will have to palletize, and I doubt they'd want to ship the gas tank.
KRAWLTEX MOTORSPORTS '93 YJ, Dana 60's, Vortec 6.0, 4l80e |
