Layout / Setup / Fixture or Welding Table 4' x 8' x 6" on stand ~36" off floor - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Tools and Equipment
Old 09-01-2010, 10:33 AM   #1 (permalink)
Member # 9467
I have what I call a layout or setup table with 3 T slots in it. It is 4'x8' and is about 6" thick hollow cast iron with webbing underneath. It was ground when new and is still in very good condition. Two slots were milled it in at some time in it's previous life and there are three holes drilled and tapped in three of the four corners. This could probably be used as a bed plate as well.
I bought it for a welding table but can't bring myself to ruin it. I was going to put a 1/4" plate over the surface but came across a similar sized welding table and thought this could go to some one that could use it for what it's intended for.
The plate is on a support table with jack screws to level it putting it about 3' off the floor. The surface has a few small dings, scratches and discolorations but they are very few. The top has a coat of Johnsons Paste Floor wax on it which makes it look dull. When buffed out it would shine.
I'm guessing it weighs in the 2500-3000# range.
I'm asking $1200 for it and can load on your trailer. I can be talked into delivery for a fee if you live within 100 miles and can prove you have a safe way to remove it from my trailer. I can also load on a semi from ground level but won't be able to move it to the front of the trailer.
I make monthly trips to central Illinois and on rare occasions go to Southern Wisconsin and would be willing to meet within a reasonable distance of either place.
I will consider trades on tools, lathe and mill tooling, 4x4 parts, guns, or?
Pics:
lt1yj is offline   Reply With Quote
Old 09-12-2010, 11:26 PM   #2 (permalink)
Member # 9467
top
