Member # 131202
Main Pit Antenna w/custom mast
Hustler Base Antenna & Custom Fabricated Aluminum Mast
Antenna Model: G7-150-1 (148-155 MHz) • Maximum power input: 600 watts FM • Gain: 7 dBd • Bandwidth: 3 MHz. under 1.5:1 • V.S.W.R.: 6 MHz for 2:1 • Impedance: 50 ohms nominal • Lightning Protection: Shunt fed direct ground • Termination: Type N female • Length: 15 ft. 4 in. • Weight: 10 lb. • Wind Survival: 100 mph • Equivalent flat plate area: 1.16 sq. ft. • Lateral thrust: 46 lb. at 100 mph • Mounting: Up to 2.0 in. OD pipe 24' Aluminum Mast (4) Six foot sections that thread together for a snug fit. Antenna breaks down into (3) main pieces and (4) ground radials. All antenna components fit into a custom made PVC container for travel & protection. Gently used but in great working order. email for pics or call/text (949) 244-2319 |
