WTB: NV4500 5th gear socket - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Tools and Equipment
Old 04-21-2011, 10:35 AM   #1 (permalink)
Member # 185127
I need to buy or rent, rent preferably, the socket or wrench necessary to remove 5th gear from a nv4500 mainshaft.
itsmillertime is offline   Reply With Quote
Old 04-21-2011, 01:39 PM   #2 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
This one?
http://cgi.ebay.com/MILLER-TOOL-6443...item3f090c0e4d
GET INVOLVED - Join the Blue Ribbon Coalition
SIGN THE PETITION - SAVETHEHAMMERS - #85
'93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K
'85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
PAToyota is offline   Reply With Quote
Old 04-21-2011, 01:54 PM   #3 (permalink)
Member # 185127
That's the one. I was hoping someone else had bought that tool that you would likely only use once then lose it in the garage and would let me rent it so I don't have to buy it to use only once and lose in the garage.
Old 06-03-2011, 08:25 AM   #4 (permalink)
Member # 137726
Any luck finding one to rent/borrow? I'll need one coming up soon too ...
MotoDave is offline   Reply With Quote
Old 06-03-2011, 08:34 AM   #5 (permalink)
Member # 185127
Nope. Go ahead and buy yourself one.
Old 06-03-2011, 10:11 AM   #6 (permalink)
oldrivers's Avatar
Member # 28570
just letting you know there are two different ones . the chevy unit uses one that looks like a ball joint socket with 4 prongs but bigger. thats if you have the harmonic balancer .
oldrivers is offline   Reply With Quote
Old 06-03-2011, 12:13 PM   #7 (permalink)
Member # 17967
How many of these things are you going to build?
If you are only going to do ONE, I think you are better off to just split the nut with a chisel, and be done with it.
You will want to buy the improved 5th gear retaining nut kit anyway, especially for a Dodge tranny, so you wouldn't re-use the original.
For some reason I've done about 12 of these things, and still don't have that socket. But if I were going to dump money on NV4500 tools, the first thing I would buy is a rear tapered roller bearing puller. I've had a few that were slip fit, but I've had a GM 2WD one that was a tight press fit. That was a nightmare...
jamesroney is offline   Reply With Quote
