Member # 4502
Super Fab Guy Super Special - JMR Bender Package ------------------>
Your JMR super hook-up Yeeaaay!:
JMR Manual Bender JMR Tube Notcher 1.75" x 6" radius 120 degree die Bend-Tech Software $1550 shipped anywhere in the lower 48. ![]() ![]() ![]() ![]()
Click the sig for everything you need to build a tube car www.SynergyMFG.com Cool stuff for your buggy, Jeep, Dodge 2500/3500 www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast |
Member # 11598
http://www.polyperformance.com/shop/...cat=189&page=1
is the correct link to the bender. The JMR benders are badass. They are much stronger than the JD2 benders, when you change dies you do not have to take off the arms of the bender. The quality difference between the two is amazing. We've got JMR's hydro bender in the shop, and we could not replace it.
This space for rent. |
#6 (permalink) | |
Member # 4502
-Bender is made from all billet material and guaranteed for life. -It uses sealed roller bearing at all the pivot points. -Won't fall apart when changing dies. -Arms are constructed of high carbon heat treated steel. -Arms are also Blanchard ground so they are perfectly flat and square. -The bender comes with a handle and quick release pin. -The JMR bender has 3 times the leverage of a JD2 bender which means only a 1/3rd of the force is required to do equivalent bends. -JMR has an anti spring back device that is available. -All the dies are heat treated and come with a life time warranty. -The dies also come with roll pins so the follower die lines up exactly every time you set it up. -The bender can also be upgraded at anytime to the ratcheting mechanism or full hydro. If thats not enough reason to spend a little extra I am not quite sure what is.
#9 (permalink) | |
Member # 4502
Member # 34369
do you take purchase orders from schools? pm response ok..
chris
[COLOR="Magenta"][QUOTE=Earl_of_Burl] Q: What is Hell? A: A place that is without God. Q: How do you find God to avoid Hell? A: Through his son, Jesus Christ. Q: What does this mean to me? A: If you are living your life without accepting Jesus Christ as your personal savior, you are on the road to Hell.[/QUOTE][/COLOR] |
#11 (permalink) | |
Member # 4502
#13 (permalink) | |
Member # 4502
#17 (permalink) | |
Member # 4502
#19 (permalink) | |
Member # 4502
#21 (permalink) | |
Member # 4502
#22 (permalink) |
Member # 4502
Its good deal TTT
#23 (permalink) |
Member # 34369
purchased a bender, three dies and the notcher... will be picking up this weekend... cant wait!!!!
chris
#24 (permalink) |
Member # 13392
looking for a good bender for schd 40 3/4, 1. and 1 1/4 with 240 dies .
i have read alot of feed back about your benders and you have definatly got my interest . i own a small metal fab shop here in wasilla alaska what would this cost me to ship here @ 99654 for the entire set up ready to go with above sizes dies . to include notcher .. thanks again wayne
if you never got stuck ,you are not trying hard enough ! |
