Ultrasonic thickness testers! CHEAP!! For tube, steel...ect <------------------------ - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Tools and Supplies
Old 08-12-2007, 08:22 PM   #1 (permalink)
MC
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
Perfect for testing block bore thickness, for extreme head porting or finding tube and frame thickness. These Ultrasonic thickness testers are one of the ultimate tools to have. Never before have they been this affordable. This testing unit measures the thickness of virtually any part and any shape.
Main Processor with Calibration block (5.0 mm) Standard Probe: end diameter: 8mm for measuring range of 1.20 - 200 mm, or 0.047 - 7.874 inch, display in both mm and inch. A Bottle of Coupling Paste Operation Manual Carrying Case Features
This unit is a handheld microprocessor-controlled ultrasonic thickness gauge specifically designed to measure the thickness of metallic and non-metallic materials e.g. aluminium, titanium, plastics, ceramics, glass, plastics including rubber and other good ultrasonic wave conductors, as long as they have parallel top and bottom surfaces. With applications in many areas of industry, this unit can perform precise measurements on various types of raw materials, components, parts and assembled machinery. It can also be used to monitor all types of pipes and pressure vessels for loss of thickness due to corrosion or erosion. This unit is easy to use and, after a simple calibration to a known thickness or sound velocity, the gauge will give accurate readings to an accuracy of 0.5%.
Sound velocities for 11 different materials can be pre-set and thickness readings can be stored in the memory and downloaded via the optional RS232c output.
The microprocessor allows fast data acquisition and analysis. This new tester features a wide measuring range, high accuracy, ease of operation, low power consumption (Four 1.5V AAA batteries), and convenient data display.
Metal Materials: Al, Fe, Stainless Steel, Cu, Brass, Zn, Ag, Au, Sn,.... Acrylic Resin, Water Glass, ... Other materials with known sound velocity values. Specifications
Measuring method: Ultrasonic pulse echo Measuring frequency: 5MHz Measuring range: 1.2 - 200.0 mm or 0.047 - 7.874 inch (steel); Actual range varies with the types of material measured Accuracy: +/- (0.5%H ± 0.1) mm Sound velocity range: 500 - 9,000 m/s 4 digit large LCD display (in both mm and inch) Automatic power-off after being idle for 4 minutes Probe contact indicator Resolution: 0.1mm or 0.001 inch Working temperature: 0 șC ~ +50 șC Communication between tester and computer via RS-232 port (optional) Size: 120mm x 62mm x 30mm (4.72 in X 2.44 in X 1.18 in) Power supply: Battery: Four AAA alkaline batteries (total 6.0V) Weight: 160g (main unit); 40g (probe)
PM me for a special PBB price
Industrial Quality CNC machines at a Hobby Price!
USA Quality is job #1
We build CNC plasma tables, click me
American Motors Engine HERE!!
1-651-433-3689
MC is offline   Reply With Quote
Old 08-17-2007, 12:18 PM   #2 (permalink)
MC
MC's Avatar
Member # 21997
A few inquiries and a few purchases.........thanks guys!
1-651-433-3689
Old 10-08-2007, 09:20 AM   #3 (permalink)
MC
MC's Avatar
Member # 21997
Perfect for porting or blockwork!
1-651-433-3689
Old 12-04-2007, 01:10 PM   #4 (permalink)
Member # 67355
nedd price
Hi I need the price of your tester. I am looking at it to check lp gas tanks
thanks Chris
groundloopdog is online now   Reply With Quote
Old 12-06-2007, 03:09 PM   #5 (permalink)
MC
MC's Avatar
Member # 21997
PM sent
1-651-433-3689
Old 12-08-2007, 04:36 PM   #6 (permalink)
DuCaTi MoNsTeR
Booger Weldz's Avatar
Member # 2931
hpow sensitive is this? IE: could it be used to test for impurities in a weld?
Www.4wheelunderground.com
Www.addictedoffroad.com
Www.hellfire-fabworks.com
Booger Weldz is offline   Reply With Quote
Old 12-08-2007, 04:38 PM   #7 (permalink)
nate379's Avatar
Member # 20099
When you say cheap are you talking $20 or $200?
PM me the price if you need to keep it a secret.
nate379 is offline   Reply With Quote
Old 12-09-2007, 05:26 AM   #8 (permalink)
Member # 64687
interest to
COMP is offline   Reply With Quote
Old 12-09-2007, 12:50 PM   #9 (permalink)
MC
MC's Avatar
Member # 21997
No they wont test concrete ir imputrities in welds. Great for tubing, steel, engine work...ect.
PMs sent
1-651-433-3689
