TN-300 Tube Notcher - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Tools and Supplies
Old 04-18-2008, 07:25 AM   #1 (permalink)
Trick-Tools.com's Avatar
Member # 32822
TN-300 Tube Notcher
The TN-300 tubing notcher is great for anyone looking to notch from ¾ inch to 3 inch outside diameter tube or pipe. This notcher is an industrial grade hole saw type notcher that provides precise notches between 0 and 60 degrees, including offset notches. The rugged notching vise uses a V-Jaw design that allows the part to stay on center with the cutter, as well as providing a better hold for round profiles. It has a quick release taper lock system that allows it to be adjusted to a new angle in seconds.
It is bench mounted and has a 1/2 HP 110V motor attached to an industrial grade oil filled gearbox, which will make quick work of any notch. It will accept any standard hole saw, which will allow you to save money by sourcing locally. The heavy duty cutting head is fed into the material with a large feed wheel. What makes this notching machine unique is that the head of the machine moves on a track of precision V-Bearings, which combined with the large hand wheel makes notching any material a breeze.
Available at the end of May for around $2,500
If you have any questions, need technical assistance or would like to place an order, please reply to this message or give me a call.
Christian Huffman
1-877-826-7268 x105
Christian@tricktools.com
Christian Huffman
Trick Tools / Pirate 4x4 Sales
877-826-7268 Ext. 105
Christian@trick-tools.com
Trick-Tools.com
Shoot me a PM with your address for a Free Catalog!
Trick-Tools.com is offline   Reply With Quote
Old 04-21-2008, 09:24 AM   #2 (permalink)
zachv's Avatar
Member # 8108
:drool: That looks like it is worth every penny.
AtoZ Fabrication, Inc.
570-385-3931--shop
570-385-3932--fax
MADE IN AMERICA---and proud of it!!!
We also offer the best service and prices available on:
Advance Adapters
Clayton Offroad Suspension
Raceline beadlocks wheels
Amsteel Winchline and accessories
ORI struts and Radflo shocks
Read my story about Todd at F&S Racing in the Bad Sellers forum
zachv is offline   Reply With Quote
