Tube Bender Mounting Plate (Infinite 8) - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Tools and Supplies
Old 09-30-2008, 08:39 PM   #1 (permalink)
Swag Off Road's Avatar
Member # 120418
Infinite (8) Tube Bender Mounting Plate
A lot of us fabricators run into a common problem when bending a long piece of tube in a standard size garage, you often run into a fixed object, project vehicle, work bench or walls.
The laser cut 3/8" thick steel Infinite (8) tube bender mounting plate allows you to rotate your bender in 45 degree increments and swing the bender 360 degrees in any direction.
Installation is very easy as you simply weld one of the 3/4" nuts that came with your tube bender to the center hole in the mounting plate then weld the mounting plate to your vertical tube bender stand. You are now able to use one of the 8 holes on the outside of the mounting plate to clock your bender arms and thus rotate your material out of the way of any stationary object in your path.
The Infinite (8) tube bender mounting plate greatly reduces the amount of tubing splices you will have to make due to limited space in your shop/garage.
Works on JD2, JMR, Pro Tools, as well as the new JD-32 tube benders.
When ordering please specify which model of tubing bender you have.
There is video showing how this plate works at http://www.swagoffroad.com/Infinite_...ing_Plate.html
Thanks Troy
Name:  Infinite 8 002.jpg
Name:  infinite 8 006.jpg
Swagoffroad.com
Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's.
Visit us on Facebook
Swag Off Road is offline   Reply With Quote
Old 10-02-2008, 02:29 PM   #2 (permalink)
hexal's Avatar
Member # 21253
nice, so how much is it?
hexal is offline   Reply With Quote
Old 10-02-2008, 03:19 PM   #3 (permalink)
Member # 120418
< $20.00, the price is listed on the website and can be purchased here.
Thanks Troy
Swagoffroad.com
Old 10-02-2008, 06:23 PM   #4 (permalink)
Big91RustyBucket's Avatar
Member # 87635
Send a message via AIM to Big91RustyBucket
How do you affix the center bolt.
~Philip
Midwestern 4x4 Parts
Originally Posted by FAUX X 4 View Post
You've inspired me to start a build thread of my own.......... all the pictures will be upside down to reflect my driving style!
http://www.midwestern4x4.com
89 S10 Truggy
Big91RustyBucket is offline   Reply With Quote
Old 10-02-2008, 06:44 PM   #5 (permalink)
Member # 120418
Weld the 3/4" nut to the center hole of the mounting plate. Then weld the plate to your bender stand vertical post, with the nut in the middle of the post.
So.......once the mounting plate is welded in place the nut is no longer accessible.
Swagoffroad.com
Old 10-02-2008, 06:47 PM   #6 (permalink)
Member # 87635
Take some pictures of one mounted. I am interested. By the way good move on the yellow star
Welcome aboard.
~Philip
89 S10 Truggy
Old 10-02-2008, 07:34 PM   #7 (permalink)
Member # 120418
Welcome aboard.
Did you check out the video? YouTube - Infinite 8" Tube Bender Mounting Plate JMR, Pro-Tools, JD2
Picture below is a prototype part but you get the same idea. The center 3/4" bolt goes throught the center hole on the mounting plate, threads into the nut that is welded to the bottom side of the plate, hence you are not able to see the nut when the plate is welded to your vertical post
Thanks for the welcome.
Swagoffroad.com
Old 10-02-2008, 07:39 PM   #8 (permalink)
Member # 87635
It all falls into place. I was thinking it was 2 flanges at first..
~Philip
89 S10 Truggy
Old 10-04-2008, 05:14 PM   #9 (permalink)
Member # 75292
I machined a solid steel 3 in Diameter spud and welded it to the bottom plate that mounts to the bender stand. I cross drilled the spud and tube to accept a 3/4 in pin. I'm using a 3 in Round, 1/4 wall pipe for my stand, ID is 3 inches. The spud fits inside the tube with a close fit. I drilled three cross holes at three different equally spaced degree intervals in the tube so I can rotate mine too, I only drilled one hole in the solid spud.
I just pull the 3/4 in pin I made out of a long bolt. I cut the threads off and rounded the end, the shank goes all the way thru the 3 in pipe. I just pull it and rotate my bender to the next hole. I dont have to unbolt anything. You idea is much simpler to build but mine is easier and quicker to index. Nice job on the invention. Mine requires some drilling/machining/cutting/welding. Yours is just a bit of cutting and welding.
1TON73K5 is offline   Reply With Quote
Old 10-07-2008, 08:55 PM   #10 (permalink)
Member # 54978
Send a message via AIM to Mud Slayer 2.0
that's a great idea.. but if you're running hydaulic bender why dont you mount your bender to a rolling stand ??
that would be another idea for ya.. market and sell a rolling stand for the bender to bolt to..ours is set up like this at the shop and i cant imagine it any other way
It's not yours unless YOU built it !
89 s10 4.3 700R4 Dana 300 Dana 44 5.13s locked on 38's
Mud Slayer 2.0 is offline   Reply With Quote
Old 10-07-2008, 10:04 PM   #11 (permalink)
Member # 120418
My concrete pad has a 3 degree slope to it, and if my bender was on wheels I would always have to make sure it was facing the same direction every time or from one bend to the next, otherwise there may be up to a 6 degree difference from one bend to the next.
If my floor was flat I would not came up with this unique idea.
Swagoffroad.com
Old 10-08-2008, 08:57 PM   #12 (permalink)
Member # 75292
Besides, not everyone want or needs to convert to hydro. Its for those of us who are not pussies and are not affraid to bend 2" DOM tube by hand. Sure it take a while longer but it's a good workout. I have 170 feet of 2" DOM in my cage....ALL bent manually.
Old 10-21-2008, 04:29 PM   #13 (permalink)
Member # 19497
Great Idea, just ordered me one!
MaTa is offline   Reply With Quote
Old 10-21-2008, 05:31 PM   #14 (permalink)
www.12voltguy.com
SeaBass44's Avatar
Member # 40
waited 5 minutes for video to load, it did not
post it on youtube so we can view it
12voltguy
info@12voltguy.com--davezoffroadperformance.com
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business. www.mudnworks.com mud@mudnworks.com
Pat's W I D E TOYOTA Front Axle
--07 KTM 450XC----with "stuff"
SeaBass44 is offline   Reply With Quote
Old 10-21-2008, 07:24 PM   #15 (permalink)
Member # 120418
I just pulled up Youtube and it worked for me.
Swagoffroad.com
Old 10-21-2008, 07:41 PM   #16 (permalink)
www.12voltguy.com
SeaBass44's Avatar
Member # 40
ok, I didn't see youtube link
the link in 1st post does not open
I watched some of the youtube video, sound is crap, full volume, then near nothing, then full, 5 minutes seems long to show off such a simple item
I might buy once I get a bender have not decided on hard mount or portable table yet
12voltguy
# 530.532.4529
Old 02-12-2009, 08:49 AM   #17 (permalink)
Member # 120418
Thanks for the orders guys.
Swagoffroad.com
Old 02-24-2009, 08:20 AM   #18 (permalink)
Member # 29474
Cool idea, I could of used one of these when I bent my main hoops...
Joshua
gt5816v is offline   Reply With Quote
Old 03-20-2009, 03:53 PM   #19 (permalink)
Member # 120418
Thanks for the orders guys,
Just got another batch of parts off the laser cutter.
As always, instock ready to ship.
Swagoffroad.com
Old 04-09-2009, 01:01 PM   #20 (permalink)
Member # 120418
Does someone have the two hole mounting dimensions for the new JD2 model 32 bender. Rumor has it that they the hole spacing, hence I will need to create a new tube bender mounting plate specific for this bender?
Thanks Troy
Swagoffroad.com
Old 04-09-2009, 05:54 PM   #21 (permalink)
troyman's Avatar
Member # 8277
Send a message via MSN to troyman Send a message via Yahoo to troyman
Just ordered the plate for my new stand
Last night I lay in bed looking up at the stars in the sky and I thought to myself, where the hell is the ceiling.
troyman is online now   Reply With Quote
Old 05-03-2009, 02:32 PM   #22 (permalink)
mattkramer23's Avatar
Member # 69958
Thanks Troy
Mine is the model 32 and I just got your plate in the mail this week. I haven't tried it yet. I will let you know if it's a go or not.
mattkramer23 is offline   Reply With Quote
Old 05-03-2009, 02:35 PM   #23 (permalink)
Member # 69958
Thumbs up
I ordered the infinite 8 tube bender plate from SWAG OFFROAD. I got my order in the mail about 3 days later. You won't find better customer service or faster delivery from anyone else.
Thanks SWAG!
Old 05-03-2009, 02:56 PM   #24 (permalink)
Member # 69958
ok I just measured the plate, looks like 2" and I know the model 32 is bigger. It's either 2-3/8" or 2-3/4" I will go out and check....any chance I can make an exchange? do you have a laser close by? I know a guy that runs one but the turnaround time is much much faster if I buy it from you!
Old 05-03-2009, 07:51 PM   #25 (permalink)
Member # 120418
Matt,
Once you get the measurement for the JD32 it takes a week from dimensions given to a new laser cut part on your door step.
Let me know I will take the std version back and swap you the JD32 bender ring.
Troy
Swagoffroad.com
