Member # 19763
What is Bend-Tech HD? Finally a tool is available to remove the trial and error out of tube header manufacturing. Bend-Tech HD allows any user to be able to design his own tube headers in minutes, providing detailed step-by-step instructions on where to cut and rotate each tubular segment. Bend-Tech HD is the only product in the world to help you design custom tube headers and break it down to fabrication instructions to use pre-bent mandrel tubing.
![]() How hard is it to use? Bend-Tech HD was designed for the fabricator. It uses terms and technology you will understand. We don’t expect our customers to have any CAD experiences and in many cases any computer experience. We are bringing a software product to your world of fabrication and we have worked very hard for you to feel comfortable with it in minutes. How do I get started? Getting started with any project is always the hardest hurdle to overcome. Creating your own header tube designs is as easy as locating points in 3D space using our state-of-art special tools of our Tri-Star and Tri-Globe. Each of these tools allows a user to place points in 3D space using familiar terms, such as; front, back, left, right, floor and ceiling. Place points at each of the tube for the header and the collector and place 2 more points showing the direction for both ends. Creating the tube is a 3D game of “connect the dot”. Start from one end of the tube, select the 2 end points and the 2 directional points and a 2-bend tube is completed. That’s it!!!! Everything else is nearly finished. ![]() How do I move the tube around to create the shape I am looking for? HD provides 2 unique ways to move the tubing on the screen. Big increment moves are best made with our “Directional Spike Collar”. Select a spike and pull the tube in that direction until it looks close to what you desire. Small increments are made easy with a function called “Nudge”. This function allows you to nudge the tube in a precision direction with ease. ![]() Want to try to even out the lengths as much as possible? As you are moving and altering your design, HD displays the length for each tube at the bottom of the screen. The length display is updated dynamically at all times. What kind of control do I have? Create your own material libraries, radii you want to use and an inventory of pre-bent mandrel bends (“J” or “U” bends) you would like to use. At any time you can change the radius of an individual bend, alter the material diameter or even “step” the material. Adding and removing bends are 2 clicks for completion. At anytime you can rotate and zoom in on your project. Collision Checking? Yes, HD will check to verify your tubes are not intersecting as well as allow you to create interference tubes and feature collision wires. ![]() How do I build my header tube? Bend-Tech HD will output a small instructional packet giving full descriptions (graphical and text) of each tube section, including; length, angle, radius and material. HD will also provide the amount of rotation needed between each tube section. ![]() ________________________ new page ![]() For customers using pre-bent mandrel tube, we went the extra mile. Select one button, “J-Bend Calculator” and Bend-Tech HD will optimize your tubing and graphically show you how to cut each section out of your inventory. ![]() If I have a mandrel bender, will Bend-Tech HD provide me proper instructions? Yes it will as long as it is coupled with our Bend-Tech SE software product. SE is our commercial tube bending software product that will give you the proper length, rotation and angle information as well as calculated cut length. ![]() Start your next custom header project with Bend-Tech HD. It will save you a ton on time and pay for itself on its first project. Stop guessing and start fabricating with Bend-Tech HD.
The site for the fabricator: www.offroadfabnet.com Bend-Tech PRO is now available!!! Design full tube chassis in less than a couple of hours with the PRO We are the developers of the Bend-Tech products. 651-257-8715 for sales and support www.bend-tech.com 10,000+ now using Bend-Tech |
Super Willie
Member # 19067
Very Cool....
Tim Lund Yeah, I wear a Kilt... what you're not man enough?! Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market! Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363 |
Beaver Pleaser
Member # 13645
This is good stuff but it should be a plug in for BendTech!
1972 GMC Submarine 383 / TH350 / 203D-NP205 / D60 / 14FF / 42's on Stazworks / heavy foote / four eyez Inclined to brute force attack a 70* incline with a Quadrajet 1997 GMC K3500 Suburban Turbo 5.3 in the works / 4L80E / HP60 SAS / PROJECT TOWHOE Last edited by florida4x4; 02-05-2009 at 07:45 AM. |
Member # 19763
Member # 19763
It is a plug in for BendTech.
It is not a free plug in for BendTech. ![]() .
